Noble Audio - the Wizard returns!
  1. Painterspal
    Thanks for the suggestion and the insight, I hadn't really thought about the cable itself. When I get a good seal with the comply all is well, although comfort could still be a tad better and I can't help wondering whether I'm getting everything the Encores can deliver sound-wise via the complys. I'll certainly have to give a cable upgrade such as you suggest some thought.
    That said, it's kind of sad when you've spent £1,800 on an IEM to have to upgrade the cable to get it into your ear properly!
  2. PinkyPowers
    It is a problem. But one I suspect Noble is working on.
  3. davidcotton
    Try inserting the iems without the cable attached perhaps? That way if you get a good fit (albeit without sound) then you know it is the cable causing issues.
    Painterspal and PinkyPowers like this.
  4. ScottFree
    While it is sad, that is sometimes beyond Noble's control. Every ear is unique in terms of the outer and inner ear geometry so there are going to be certain parts of the population where a Noble UIEM or any other UIEM will not fit properly in the ears regardless of whether the cable fits properly or not.
  5. Solarium
    I ordered both the Symbio tips as well as the triple flange tips from amazon, hopefully it'll fit!
    For the moment, I was able to finally get a good (albeit painful) fit on my left ear with the medium Comply 500 tips. All other tips either did not give me a proper seal or just didn't fit. I had to really shove the big ass tip into my left ear though, and it seemed to be uncomfortable even after 5 minutes.
    Luckily my right ear don't seem to mind any type of foam tips.
  6. Painterspal
    Agreed, although there does seem to be a significant number of comments here about the difficulty obtaining a satisfactory seal with this particular IEM. More than on other IEM threads? I've no idea - there are a lot of threads I haven't read. However, I'd just restate that I've never had a problem previously with other IEMs, including a wide range of high end models. And isn't the clue to my concern in the title - UIEM = universal. I suppose it is unrealistic to expect 100% of the population to get a good fit but if you shell out a lot of cash you'd like to hope this had been thoroughly sorted out for the overwhelming majority, i.e. 99.9%.
    That said, I have managed to get a seal after a lot of trouble and they do sound excellent - better than any others that I've tried.
  7. Kunlun
    Noble Kaiser on Massdrop for $899. Definitely worth checking out!
  8. PinkyPowers
    Indeed! That's an exciting collaboration. If I had a little more money to spare, I'd jump all over this Drop.
  9. Terco
    This is not the encore version right?
  10. AndrewCanDo
    No, it'll have the previous K10 signature.
  11. Solarium
    That's very true, the stock cables stick out too much into my ears preventing fine tuning of the IEM shell adjustment to get a proper fit. I checked out the plugSound website, which do you recommend? But honestly I didn't plan on spending another $200+ on cables on top of the IEM though :O
    After finally getting a semi-good fit after running through various tips (I ended up with the original foam tips but with a different angle of insertion), I gotta say, I massively prefer these to my SE846's. The Encores have IMO a VERY generous portion of bass, very extended trebles, and amazing mids. I honestly can't find any fault with the sound signature. I'm getting used to the treble, and my ears are getting accustomed to the sound. The more I listen to these, the more I like them.
  12. FullCircle
    It isn't the Encore
    Noble Audio Stay updated on Noble Audio at their sponsor page on Head-Fi.
    https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
    PinkyPowers likes this.
  13. Astral Abyss
    Still... seems like a really great deal. I mean, how many 5 star reviews did the K10 get anyway?
  14. PinkyPowers
    You sneaky Wizard! This sure came out of nowhere. Congratulations on an excellent project!
    [​IMG]
  15. FullCircle
    29
    Consecutive 5 stars
    Screenshot_20171003-200749.png I
    CEE TEE and PinkyPowers like this.
