I rently notice there is some condensation on the bore of my k10u... is it fine?
Is currently winter here in Melbourne though....
Hey guys, I'm currently using a Campfire Audio Jupiter and I'm looking to move up to either the Katana or K10E. Which one do you think matches the Jupiter's sound stage the best? Thank you in advance.
P.S. I'd prefer something neutral, but with the bass slightly north of neutral. I really dislike sibilance, and will be listening to music from the likes of Chicago, Tower of Power, Ambrosia, Toto, Aretha Franklin. Thanks for the help
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
Thanks!Welcome to the biased family.
I highly recommend Toxic cables. I found out about them here. Only custom cable I've ever bought and used so far. Check it out! The quality is fantastic.I will be looking to get aftermarket cables for my Noble IEM's since i will be pairing them with the Sony Walkman that uses the Pentacon 4.4mm balanced connector. Any recommendations on the cables? I am not looking to alter / change the sound signature much
cool, will check them outI highly recommend Toxic cables. I found out about them here. Only custom cable I've ever bought and used so far. Check it out! The quality is fantastic.
Effect audio lionheart has amazing synergy. I use it with my k10s and Sony wm1z. Updated my feedback on effect audio threadI will be looking to get aftermarket cables for my Noble IEM's since i will be pairing them with the Sony Walkman that uses the Pentacon 4.4mm balanced connector. Any recommendations on the cables? I am not looking to alter / change the sound signature much
OMG! Glorious!
