You mean Dali iO-8, right? The iO-6 is way cheaper.in a limited time,
I have to choose one of the two
both are the same price
Noble apollo
Dali io6
I made a comparison between the iO-8 and the Apollo so maybe it helps you.
The Dali iO-8s arrived today and I did a first comparison test:
Sound:
Treble: Winner - Apollo. I love the plucked sound of the balanced drivers. They seem much more present and subjectively higher resolution and more brilliant.
Mids: Winner - Dali. In my opinion, they sound more natural and better separated with the iO-8. I particularly noticed the more natural sound with vocals.
Bass: Winner - Dali. Both models play really strongly here, but the iO-8s play a little deeper and, above all, more controlled.
Spatiality: Winner - Apollo. The ear pads are deeper, which already contributes a lot to a more open impression. In general, the Apollo sounds more airy and builds a nicer stage.
Homogeneity: Winner - Dali. I don't know whether it's simply because two drivers don't have to work together, but everything comes from a single source, but the iO-8s are even more homogeneous and offer very good transitions between the different frequency ranges.
ANC & transparency mode
ANC: The Apollo have the stronger ANC and filter out background noise more effectively. I consider the Dali iO-8 to be more on a par with my previous Bang & Olufsen H95. However, the Apollo picks up footsteps very clearly and unpleasantly. The Dali are much more pleasant without such an effect.
Transparency mode: Slight advantage for the Apollo, although both perform at a good level. However, neither of them comes close to the level of the B&O H100 and therefore most likely not to that of the Airpods Max (I have never tried them).
Comfort:
Both headphones weigh almost exactly the same. The Dali iO-8 weigh 5 grams more (335g Apollo vs 340g Dali), which is negligible.
The earpads of the Apollo are much more comfortable, which is due to the fact that they are deeper and oval-shaped.
The Dalis are not uncomfortable because of this, but people with large ears might not be as enthusiastic.
Despite the same weight and the actually thicker padding of the Apollo headband, the Dali iO-8 is still the more comfortable for me at this point, as it doesn't cause a hotspot on my head, unlike the Apollo.
Handling:
Very similar. In both cases, the ear cups can be rotated in both directions, but are not foldable. The size adjustment works with a clicky grid on the Apollo, without a grid on the Dali, but still very comfortable and secure.
In both cases, the buttons are operated via buttons and not via touch gestures. However, I still think the Dali solution is better.
Build quality: Very equal. Both models rely on a mix of leather, fabric, aluminium and high-quality plastic.
In my opinion, the Dali look a little more elegant and appealing and don't sit on the head quite as expansively as the Apollo. But of course this is all a matter of taste. However, I am pleased that Dali also has a cream/white/brown version in its portfolio alongside a black/grey version.
Conclusion: Both models are really good and have their own strengths. For me and my intended use, however, the overall concept of the Dali iO-8 seems a little more rounded than that of the Noble Fokus Apollo, which is why I will probably opt for the Dali.
In my case, the Apollo will have to go back anyway, as the headphone jack is defective.
