no sound above 96 kHz
Mar 16, 2013 at 4:54 PM Thread Starter Post #1 of 3
CB3874
Hello,
Here is my current setup  :
27" late 2009 iMac > USB to NuForce U192S >  Optical to Schiit Gungnir > RCA out to Rega Brio R Integrated Amp
There is no sound above 96 kHz sample rate. The blue & white LED between 192 & 176 is on the NuForce U192S but no sound. All other bit rates are fine. I can see the sample rate change in the Audio MIDI setup.
Is there something I'm forgetting to configure? How do I resolve this?
Thank you!
CB3874
Mar 16, 2013 at 7:01 PM Post #2 of 3
sterling1
Your DAC to analog is not accepting anything above 24/96. Re-set computer output to 24/96 and you should be good to go. Or set the Schilt device for 24/192. That setting would only be useful if you had some HDtracks material in hi rez.
