No Left Channel In Pimeta
Jul 22, 2004 at 5:48 PM Thread Starter Post #1 of 31
Madcat05
I hooked up my pimeta and when I turned it on I get the right channel but no left. Along with there not being a left channel, after about 10-15 sec the sound fades out and I get a crackling noise and then the sound fades out.
unfortunalty I don't have a DMM right now so I can't do a real test.
Anyhelp? Thanks.
Jul 22, 2004 at 6:22 PM Post #2 of 31
eyevancsu
Is your pimeta cased up? If you mix the input and output grounds on your pimeta (like using a metal case), it will cause the sound to fade out after a few seconds, and cause your tle2426 to overheat (scald your fingers).
This may not apply to you, but it happened to me a while back.
Jul 22, 2004 at 7:32 PM Post #3 of 31
Madcat05
no it isn't cased yet, it is sitting on my wood desk. wood wouldn't affect the amp would it?
Jul 22, 2004 at 7:45 PM Post #4 of 31
tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
If you've soldered jacks onto the cables running to the board, desolder them and use alligator jumpers to attach the cables. You may have damaged one of the connectors with your soldering iron, which can make chips overheat and shut down; that's what your symptom sounds like to me.
Any other tests I'd want you to do will require a meter.
Jul 22, 2004 at 7:49 PM Post #5 of 31
Madcat05
Well I regrounded the inputs and I'm getting both channels now.
But in both channels there is crackling and its as loud as the music.
Jul 22, 2004 at 9:33 PM Post #6 of 31
tangent
Go over all the connections. If your input jacks' soldering wasn't good enough, other joints may be bad, too.
Are any of the chips getting hot?
Jul 22, 2004 at 10:13 PM Post #7 of 31
Madcat05
nope, no chips are hot. they are are all cool.
should the buffers be flush with the sockets? Because mine are slightly raised. I don't think I pushed them in all the way.
Jul 22, 2004 at 11:09 PM Post #8 of 31
Madcat05
Well I'm not gettting any crackling anymore. But I still can't get the left channel.
EDIT: The AD8620 is getting hot when the amp is on now.
Jul 22, 2004 at 11:45 PM Post #9 of 31
tangent
Push firmly down on them. If they go down farther, they weren't in all the way. If they don't move, they're in.
It's oscillating or damaged. Swap in another dual op-amp to figure out which.
Jul 23, 2004 at 12:19 AM Post #10 of 31
Madcat05
Can I push the buffers while they are soldered to the sockets?
Is the OPA627 or the OPA637 dual? And I don't have any browndog adapters either.
And what does oscillating mean again?
Jul 23, 2004 at 1:22 AM Post #11 of 31
tangent
If they're soldered, contact is as good as it's going to get.
It's quicker for you to ask that and wait for an answer than to read the datasheet and find out?
The Search button is your friend.
Jul 23, 2004 at 1:40 AM Post #12 of 31
Madcat05
Ok I'll search next time. I contacted my supplier of the opamps to see if they were working when he had them.
When I first turned on the power I didn't know how far to puch down on the opamps. So they were just sitting on the sockets, then I pushed them in while the amp was on. This could probably affect them right? And if could the AD8610 isn't getting hot.
Jul 23, 2004 at 2:09 AM Post #13 of 31
tangent
That's helpful to know, but not conclusive. There are many ways to kill a chip, and it can happen at any stage after your supplier pulled them out of their test rig.
Possible, but I wouldn't bet on it. Usually when a chip isn't fully inserted, it just doesn't work.
Can you go down to Radio Shack and pick up a TL082 to test with? It'll run you $2.
Jul 23, 2004 at 4:25 PM Post #15 of 31
Madcat05
I didn't find any TLO82s at Radioshack. I also put a OPA637 in and I get only the right channel. I also have to turn the volume up all the way to hear it.
