ShakeThoseCans
Thanks. I'll try the bass medium tip.
I use Sedna Earfit Light Short tips. The stock balanced tips are also good. For me, the stock bass tips were too bassy and muddy sounding on the NA2. The NA2 sounds really different from the NM2+.Are there recommendations for eartips for the NA2?
I am looking for something size-wize about in-between the stock small and medium tips. Looking for a good seal.
I picked up a package of Acoustune AET08 after @audio123 had recommended them in this thread for the NM2+, and I am really pleased with that pairing on my set. They are just really good tips in general, very nice in terms of grip, feel, and keeping their shape to maintain a perfect seal. Neither of the stock tips kept a perfectly stable fit/seal for me, nor do they sound as clean as the AET08 sounds.
Glad my recommendation helps. Enjoy the music.I picked up a package of Acoustune AET08 after @audio123 had recommended them in this thread for the NM2+, and I am really pleased with that pairing on my set. They are just really good tips in general, very nice in terms of grip, feel, and keeping their shape to maintain a perfect seal. Neither of the stock tips kept a perfectly stable fit/seal for me, nor do they sound as clean as the AET08 sounds.
Whenever you’ve had sufficient time to listen to the NM2+, I’m curious how you think it compares to the NM2, and especially to the Oxygen.I picked up a package of Acoustune AET08 after @audio123 had recommended them in this thread for the NM2+, and I am really pleased with that pairing on my set. They are just really good tips in general, very nice in terms of grip, feel, and keeping their shape to maintain a perfect seal. Neither of the stock tips kept a perfectly stable fit/seal for me, nor do they sound as clean as the AET08 sounds.
I think the NM2+ is pretty much superior to both NM2 & Oxygen.Whenever you’ve had sufficient time to listen to the NM2+, I’m curious how you think it compares to the NM2, and especially to the Oxygen.
I think the NM2+ is pretty much superior to both NM2 & Oxygen.![]()
You have the NM2+, the LZ A7, and the FH3, yet you crave the FH5? May I ask why? Just curious.Wow ok I just tried the RHA dual density tips with the NM2+, they are PERFECT. I get no hint of glare in the upper mids with these tips. They are very cheap direct from RHA as well. Definitely worth a try.
Almost enough to quench my lust for the FH5. Almost.
Yep typo! Meant the new FD5. Have been pondering selling the NM2+ and FH3 to replace both with the FD5 if it lives up to the early hype.You have the NM2+, the LZ A7, and the FH3, yet you crave the FH5? May I ask why? Just curious.
Edit: Wait, did you mean the “FD5” single-DD IEM?
