NewFantasia Replacement Audio Upgrade Cable for Sennheiser HD598
  1. mohsin9221
    Ok I`m 100% its not a placebo effect, it all started when i bought used Sennheiser HD598 from a local chap, he throw in a very nice storage box along with this replacement cable and since from the start I put in this cable because it was shorter in length (1.2m) than original. I got used to listening to that cable and few days ago just out of curiosity I plugged in original cable and guess what? I was listening a different sound dynamics. At first I thought it was some placebo effect so I took some time to check this my self, my wife and a friend (blind tested with them) and they can hear a difference in sound too, here are my findings
    Original Cable
    * Sound volume is low
    * Higher dynamic range
    * No distortion of any kind
    * Mids/Treble has good separation.
    * Bass is less tight, <100hz is like invisible
    New Fantasia Replacement cable
    * More sound volume
    * Bass is fuller upto 20hz, more punchy
    * More sparkle in upper mid range but its overlapping higher frequencies so vocals sounds muffled sometimes.
    * Less dynamic range.
    * More echoing sound (wider sound stage may be?)
    Depending on your listening preferences you may or may not like that change in sound stage but I like my headphones to sound flat with good separation.
    Here are the links, Seller claims it to be OFC wire
    https://www.amazon.com/NewFantasia-Replacement-Sennheiser-Headphones-1-5meters/dp/B00KAKGQCQ
    http://newfantasia.net/Product/5790383032.html
