Newbie help :)
Dec 27, 2009 at 1:10 AM Thread Starter Post #1 of 18
rydude07
Hey guys!
My history of headphones: I use an ipod touch an listen to rap and r and b a lot. I also occasionally listen to rock and alternative and chill music.
Anyways, I bought sennheiser cx300 before and sony ex75 before. They all broke in less than about 1 year.
I want to move up to something better. I was looking at amazon.com for etymotic ER6i but worried about the bass...would the bass be somewhat good if i use the EQ to bass booster on my ipod touch. They are selling for 60 on amazon and not through a third party. I checked etymotic but they dont mention if amazon is an authorized dealer though.
I was also looking at the shure se115. They are selling for 100 on amazon or 62 bucks thru sarjo wholesalers. Would you trust sarjo? If yes I would probably get those.
I want to spend less than 100 on earbuds.
Thanks!! Please help as I am deciding tonight.
Dec 27, 2009 at 1:18 AM Post #2 of 18
The lower end Shure's aren't very good. I would suggest the RE0. Highly recommended here on head-fi
Dec 27, 2009 at 2:00 AM Post #3 of 18
i would actually go with the klipsch S4. They got a 2 year warranty and sound great after around 100 or so hours of burn in. They go for $79 shipped from sound earphones but you can get them cheaper in the FS threads if you search for them.
Since you seem worried about the bass of the ER6i it *probably* is not enough for your tastes coming from a cx300. The same can probably be said for the RE0.
Dec 27, 2009 at 2:21 AM Post #4 of 18
I've got similar music tastes to you and I bought the RE0s a few days ago, hopefully they'll come soon. Of course you're coming from the bass heavy CX300s so you might not be satisfied with them at first.
Dec 27, 2009 at 2:22 AM Post #5 of 18
So the er6i with bass booster probably wont help too much eh?
So you think the klipsch is probably the best for under $100? I want to make sure they last more than a year at the absolute least.
Seems from ilounge that the klipsch got a B where the etys got an A.
You would go for the klipsch over the shure se115? I dont really want RE0, wanna stick to the more name brand headphones.
Dec 27, 2009 at 5:33 AM Post #7 of 18
From what I've seen around here Hifiman/Head Direct are decent companies (I mean, they've got their own dedicated forum, so they can't be that unknown). However, I get what you mean. The etys are known for their accuracy, but not for their bass. That isn't to say there isn't any, you may find that after listening for a while you like them (never owned them so I can't say from personal experience).
Just remember, the more famous the brand the more you'll pay (look at Monster).
Dec 27, 2009 at 5:37 AM Post #8 of 18
Thanks! So which you think should last longer the shure se115 or the denon AH-C551K?
I want something that is not bad in the bass department as I listen to Rap and R and B a lot and rock sometimes (sometimes Jason mraz and chill music like death cab for cutie).
Dec 27, 2009 at 5:53 AM Post #9 of 18
If you dont want the RE0 or the S4, since its hard to recomend the SE115, sound like you would be happy with the Denon AH-C551K.
Dec 27, 2009 at 5:54 AM Post #10 of 18
I never owned either. I do have a pair of shure SCL3s and as best I can tell they're solid. The cord is thick and they've survived a year of abuse in and out of my pockets. I can also give you my review of my RE0s when they arrive.
Dec 27, 2009 at 8:38 AM Post #12 of 18
If you're thinking Denon then then why not the C710 or C751? The C551 are decidedly not on the same level as the RE0 or even the Klipschs.
Dec 27, 2009 at 8:46 AM Post #13 of 18
The C710 and C751 are too expensive.
I am looking at the shure se115- $60
Denon C551-$54
Etymotics (most likely not but ill just put it here) - $62.
The denon C751 is $96 and dont really feel like spending that much.
The klipschs are $80 and are just a bit over my budget as well.
Dec 27, 2009 at 8:49 AM Post #14 of 18
I would have a hard time recommending any Shure IEMs at the moment. I've had three pairs which have all had shorts develop in the cable in less than a year of use. If you don't mind being with out them for a little while, you can send them away for warranty replacement through Shure provided you buy from an authorized dealer. Sometimes they will be nice and replace them if you don't - but don't count on this as I've had Shure refuse to replace an IEM that purchased new in box from an unauthorized seller, despite the fact that the cord developed a short in three months of use. I think I treat my gear pretty well, but I have had no had good experiences with Shure's products.
