johnbthetenth
- Mar 16, 2011
X3II: Only in Rockbox -> I have a Folder.jpg in the album directory. This doesn't show.
Are you referring to that player in particular? I have multiple different rockboxed players, none of these has this issue. All work fine with folder.jpg.
the latest version did scan past 15,000 which is good.Did you try to update music library after installing new firmware?
Hi everyone,
I think xDuoo X3II users might be interested in my custom firmware. I made some reverse-engineering tricks over stock v1.2 firmware and implemented a lot of interesting things. The most interesting are:
Project page on GitHub: https://github.com/SinuXVR/xDuoo-X3II-custom-firmware
- UI speedup and brand new design
- Changeable UI themes (12 built in + unlimited amount can be loaded from SD card)
- Battery levels and brightness levels fixed
- All five DAC's digital filters implemented
- Extended EQ adjust range
- DSD noise fixed (stolen from last X20 firmware)
Just download update.upt file and you know what to do
I can't confirm, everything works as expected for meHowever, it seems to have broken the bluetooth hiby link
I have put bluetooth libs from TempoTec V1 firmware. You can't see current bt codec in sink mode, player doesn't display it. You should check it on the source device. On Android it can be done in "Developer options"how did you do that?? and how you had a confirmation that ldac or aac are effectly working?
i don't see AAC indicator
tossing up between the x3II or the x20, I've never had xduoo before though, finding it tough to make the call.
