New to audio, need a bit of help
post-10538499
Thread Starter
Post #1 of 11
Pyregeth
So I currently bought the Sennheiser HD 380 pros, and noticed they didn't sound all that great on my pc (Asus Xonar DSX Sound Card) but sound amazing on my phone (Galaxy S5)
Would a headphone amp fix this issue? Was thinking about buying this https://www.mayflowerelectronics.com/shop/digital-to-analog-converters/objective2-odac-combo-with-rear-power/
Any help is appreciated.  I'd like to eventually take out my sound card for better airflow to my GFX cards as it's right in between both of them and constricting airflow to one of the cards.
(Sorry I'm really new to this ;-; )
post-10539276
Post #3 of 11
Lorspeaker
it might sound better....take a chance...if u have the cash...give it a shot...u know u WANT TO ? ! :p
post-10539281
Post #4 of 11
Pyregeth
well I need it to be louder (as it is louder on my phone) and not have say my music get louder at one part then go quiet at another part (while I'm playing csgo / bf4)
post-10539291
Post #5 of 11
jodgey4
It could be that the DSX has a high output impedance that is causing bloating and a lack of detail and cohesion. An amp could certainly remedy this situation. Also, if you remove your sound card, you won't be able to use its virtual 7.1 processing for gaming.
I'm about to go play some CSGO myself.
post-10539299
Post #6 of 11
Pyregeth
to my understanding my card is designed more for a media PC (home thetre setup) and doesn't even have a headphone amp. not like the DGX Card.
and I personally don't care (for now at least) about surround sound as the only surround sound headset I like is the Logitech g35s or else the razer tiamat analog 7.1 headset :p
post-10539321
Post #7 of 11
PurpleAngel
California
California
Hopefully you disable the motherboard's on-board audio? in the BIOS, when you added the DSX.
The Xonar DSX's headphone/front speaker output jack is more like a line-output (for speakers), that pretends to also function as a headphone output.
I'm guessing the Xonar DSX gives the HD380 Pros a bloated (louder, less detailed) bass.
And chances are your Galaxy 5 headphone output is really designed more for headphone use.
I'm assuming your a gamer (dual graphics cards), so you would want to be able to take advantage of any audio features.
Schiit Modi optical DAC ($99) and Schiit Magni headphone amplifier ($99).
The optical Modi can connect to your current sound card (DSX) and if you remove the DSX, you can connect the Modi to the motherboard's optical connection (using the motherboard's built in sound card).
Using optical will allow you to be able to still use sound card features, where as USB bypasses sound card features.
post-10540410
Post #8 of 11
Pyregeth
soooooo...optical > usb? :D
only thing I like about my sound card is the EQ ;-;
post-10540551
Post #9 of 11
cel4145
grand rapids, mi
grand rapids, mi
No. Not better in sound quality than USB. But USB DACs completely bypass the sound card in a computer. Opticals plug into the sound card, and so can make use of their digital processing, such as your EQ or if you had virtual surround. But if you don't need that, USB or optical connection will be pretty much the same.
post-10540573
Post #10 of 11
Pyregeth
I just use the in-game headphones options since it does fine for me.  If I need surround sound I'd go back to using g35s or something else.  :p  Had a mic issue with my last few headsets so ended up getting a blue yeti mic.
post-10540643
Post #11 of 11
cel4145
grand rapids, mi
grand rapids, mi
Then you could definitely go for optical or USB for a DAC and get rid of your sound card. If you want to EQ the sound for music, some music players are better than others.
I like the ODAC/O2 you are considering (I have the ODAC). But arguably, the Schiit Modi/Magni is comparable in quality for less money.
But there are also better headphones for surround sound than the ones you described that are just regular audio headphones. But to get the virtual surround effect those gaming headphones have, you'd need a sound card that has that feature.
