Misterrogers
MOT: Joe Audio
- Jan 29, 2011
I was fortunate enough to be selected for the beta and there's no way in $%^$# I'm sending this thing back.
That says a lot right there. If the Rag is that good and much more favorable price, it's kinda not too smart not to consider that.I was fortunate enough to be selected for the beta and there's no way in $%^$# I'm sending this thing back.
I understand that you personally didn't like the GS-X but your hyperbole makes your other opinions suspect.
It's no surprise that the GSX2 is a horrible combination with the HD800.
From your memory what can you say the HD800 sounds like on the RAG when compared to DNA Stratus? Can the RAG push the performance of the HD800 to where it would be if driven by the Stratus or EC 445?
I was hoping to be oblique; that by being oblique, I could avoid answering all together. My statement was not intended hyperbole, otherwise I would have said something like this: "sizzly etched analytical SS abomination" (not my statement BTW, just to be clear, but there is a grain of truth to that opinion, pun intended).
Allow me to be more direct without hyberbole so that my opinions will be "less suspect".
IMHO, FWIW, my 2 cents, the GS-X mk2 is not in the same class as the Rag. While I do think the GS-X mk2 is a good amp, I've never thought it was a great amp, especially considering the recent price increase. The quality and the beauty of the GSX2's construction is top notch. But that is a low priority for me. I'd rather pay for sound quality than sexy looks.
The GSX2's strengths are clarity and resolution, and even in that sense, it's not nearly as resolving as the Rag. The GSX2 is about on par with the Mjolnir in terms of resolving ability. Where I am disappointed with the GSX2 is its tonality and treble behavior. It is a lean sounding amp. Not necessarily bright, but rather lacking in bass, particularly with impact. The treble can be rather etched, edgy, with sheen, etc. some silbilance, no glare. The detail presentation is a little bit "in your face" (which I don't mind), but just pointing this out because the Rag is more resolving, yet much more subtle about it. The Rag has a better ability to distinguish different similar volumes of sound. It's more nuanced. Less "square" - to borrow a phrase from someone I know.
So in terms of bass, the Rag is still subtle in bass, yet still not as lean as the GSX2, but much much more muscular. The differences are immediately notable with something like a track from the recent Daft Punk record. Abyss from Rag is like "Ho Lee ***". GSX2 bass is like "hmmm, where's the beef?"
In terms of treble, we are talking about worlds apart. I've heard both Rag and GSX2 on M7 and MSB Analog DACs respectively (and also with a variety of mid-tier SABRE DACs. With the buttery-smooth sounding ladder DACs, the Rag is so smooth. I've said this so many times now. Like ice after the Zamboni. The GSX2, with the MSB Analog and neutralish headphones still exhibited that etched, edgy sheen. (BTW the Rag treble loses its smoothness with grainy DACs.) So what does that tell me? Which amp is more transparent? (I hate the pull the "transparency" card because nothing, nothing I've heard is transparent, and "tranparency" is such a weasel word, but the Rag is the closet amp to that.)
It's no surprise that the GSX2 is a horrible combination with the HD800. A pretty decent one with the LCD3 or HE-500. I like the GSX2 with the HE-500 the best. The HE-500 has a tendency for thick "one-note" bass where the GSX2 is a good antidote. With the LCD3, I found the relative lack of impact or balls in the bass troubling. The Abyss wasn't a good match either. Some treble issues and like the Audeze, the bass just wasn't up to par. I'm not sure how much power the GSX2 delivers, but I've found the Abyss to like lots of power for good bass control and impact.
The GSX2 has three gain positions. At the lowest gain position, the treble is much more controlled. However this position also seems to make the amp sound flatter - less lively. At the highest gain position, the amp comes alive, but at the cost of more uncontrolled very active treble. So it's like you can't win. I would have though much higher of the GSX2 if it could had the liveliness of the high position and the more stately treble of the lowest gain position. (In contrast, the Rag also has three gain positions. All gain positions sound the same.) Still the GSX2's thin tonality and lack of real resolution at that price point makes me balk.
As I said earlier, the GSX2 is not the same class of the Rag in terms of sound quality. So where does it fall? It's about in the same class of the Mjolnir. Both GSX2 and Mjolnir are amps which I consider to be good, but different sounding. Good equipment is not excellent, therefore "Good" stuff will have some flaws. Both the GSX2 and Mjolnir have flaws, different kinds of flaws. From a personal sonic priority point of view, I find the strengths and weaknesses of the Mjolnir more palatable to me, especially considering its price and flexibility (I used Mjolnir at one time to drive 8 ohm speakers). Others may find the GSX attributes more suitable to them. I would not hesitate to recommend the GSX2 to someone who I knew would like its sound.
What it comes down to is what do you like with your headphones.
I was hoping to be oblique; that by being oblique.....
We will have to agree to disagree about the GSX. I haven't heard the Rag so can't offer an opinion between the two, but I found the GSX outperformed the Mjolnir when I had them both for a few weeks.
Did you compare the Rag and the GSX at the same time, or are you working off memory?
I read on this site where you said the Dynahi was grainyFunny stuff
