Fiziks
- Apr 26, 2007
Hello, I'm looking into getting into audio. First, what I have-
Foobar FLAC > SB Audigy 2 ZS > Pioneer VSX-454 > HD580
I'm looking into upgrading both the sound card and the amp with a budget of around $300 or less. My needs/uses for these will be mostly gaming (BF2, Counter-Strike) and Music (foobar FLAC / iTunes). I would also need a 1/8inch mic input jack and 1/8inch output for LANs where I would not care about quality.
I as far as sound card, I like the HT Omega CLARO. After a little searching on here it seems like a good card for the price. What is the major difference between the CLARO and the CLARO Plus+? For what I'm using it for is it worth the difference in price?
As far as an amp, I am swamped with options, and I really don't know where to look and what to look for. Tube or not? Portable or not?
I would like to use the Optical out on the Claro as the input on the amp. Any suggestions on products and retailers would be helpful.
And a few other random questions. I have my current setup plugged into a crappy UPS. Would line noise transfer into the amp? would upgrading the UPS be worthwhile? I'm also using Radio shack cables and stock headphone cables. Will upgrading these make a real benefit for my uses? What cables would you recommend?
