BoilermakerFan
- Jan 2, 2008
Here is image of a dial I was thinking of...
I think the set screw holes would look better on the inside
You all are killing me with the kindness ...
I have no plans of building any amps right at this moment..
I am thinking about a Beta 22 but since SkyLab thinks its not a whole lot better than a Dark Voice and same price and no labor I just my buy Dark Voice amp but nothing in stone yet...
I may make a rack and some of those pointy brass feet for my equipment that they use on high end amps? Is the purpose? Or is it just to get air space under the case or some other high tech reason?
ENJOY
A RK27 shaft will be long enough to accommodate that design. It will work fine.
Skylab has auditioned more equipment than most guys can dream about, he's well respected, and a friend, so I respect his opinion though I haven't heard a Dark Voice. The big point of contention with a B22 is that they go up in smoke so easily. Even very experienced builders have had a B22 go up in smoke while commissioning a new build. Even if you buy one already assembled and tested, there is a risk of damage occurring in shipping. Then just forget to turn off the power to your B22 just once before unplugging your headphones and you'll never forget again as you'll be pulling bad parts off the boards, then chasing down the ones hiding after you think you have all the badly charred parts replaced.
The cone feet concentrate the weight and make the amp or rack very stable and minimize vibration. If the rack is designed correctly to distribute the weight properly, a 3-point tripod is a better base than 4-points, but if too much weight is on one side, it will tip over. If your making them, why not use bronze? It's a much denser metal and less brittle than brass.
