ch1n4
- Oct 21, 2011
Listening to the Beyerdynamic T1 (original version) there is still a hint of sibilance and the well known treble peak, but they do sound very good out of this amp.
Again I'm using it on low gain and the volume knob is only at 10/11 o'clock.
The sound is dynamic, full and detailed. Very good synergy here, I can imagine it would sound excellent with the T1 2nd generation also.
Also the amp doen't generate a lot of heat, it stays cool even after a couple of hours of listening. I will be testing this as an Amp/DAC combo soon rather than only amp.
Thanks for your impression! Sounds the amp section is very good.... what do you think about the dac section respectively using the unit as Dac/Amp combo.
So I can conclude from your comments it doesn't sound dry, analytical?
