New JVC Wood - HA-SW01 and HA-SW02
Jun 4, 2023 at 5:37 PM Post #166 of 184
So this is the SW01 driver:
Jan 10, 2024 at 7:16 PM Post #168 of 184
It’s such a small thread.. I believe people just don’t care anymore. Although I’m sure these still pack great punch.
Jul 24, 2024 at 10:32 AM Post #172 of 184
They are not the punchiest headphones but they do have a warm and relaxing bass presentation and really excellent at intimate vocals.
What about pEQ potential? I love to EQ my stuff.
Sep 1, 2024 at 2:19 AM Post #173 of 184
How do these hold up in 2024?
Sep 1, 2024 at 5:19 AM Post #174 of 184
These were always something of an outlier even when they first came out.
• They're bigger than portable and studio monitor closed-back headphones, but not as big as proper full-sized closed-back headphones.
- so they're 'medium' size?... which is a bit of an unusual placing.
• The tuning is WARM
Some 2nd hand copies show significant flaking on the headband (difficult to know how much is from abuse or just normal use - mine still look like new ¯\_(ツ)_/¯ )
Objectively, the tuning is not 'accurate'.
Subjectively, the tuning makes these sound VERY smooth and laid back which in turn makes these deceptively detailed.
It doesn't force you to hear all the detail, but that doesn't mean the drivers aren't capable - the detail is there, and if you EQ these to a more balanced sound, they sound even more 'high-end' (whatever that means).
I'm now using mine with Yaxi STPad2 pads, which is a huge comfort upgrade, and maybe gives a bit more staging, I would strongly recommend upgrading the pads, as the stock pads are simply awful for comfort and fit.
When using these outdoors, I also usually just add a small sub-bass boost to make it more linear at the very bottom end, which does roll off a touch.
If the goal is highest-end audiophile purity OUT OF THE BOX, then these are not it.
But if you want something to relax with in contrast to the ultra high end detail monsters, then it's still a very good choice, especially with some of the 2nd hand prices now.
Sep 1, 2024 at 10:03 AM Post #175 of 184
it’s a good take!
These sound amazing still after 8years (I have the same pair since release)
Flaking happens with age, after 2-3 years because it’s faux leather.
Stock pads are going to garbage.
Very sensitive to cables and pads, many tuning options considering that.
Strong simple connectors and most accessible plug meaning you can build and experiment with your own diy cables for it.
Not the reference tuning, musical and enjoyable to listen.
Amazing sound with Chord Mojo.
Sep 1, 2024 at 10:10 AM Post #176 of 184
Nice take.
This kind of sound how I would describe the tuning they put for my JVC-VICTOR HA-WM90-B headphones.
Sep 1, 2024 at 10:50 AM Post #177 of 184
I'd like to audition one of those one day; the price is just too much of a turn off.
Good to hear Victor/JVC might have found their signature 'flavour'. I think historically, they've always had a bit of an identity crisis.
Sep 1, 2024 at 12:46 PM Post #178 of 184
“Warm” is a relative term and I would define “warm” as tilting more toward bass and lower mids than upper mids and treble. These are not “warm” to me. I would describe them as mid forward. They bring vocals very close and present them in a thicker way. They are for me a vocal master if you like your vocals brought forward and accentuated over all instruments in a track.
Oct 21, 2024 at 4:25 AM Post #180 of 184
I forgot to post this last time regarding the YAXI stPad2-LR.
The 'leather' pad is the same as the one I mentioned previously on aliexpress - "leather MDR-CD900ST pad".
In this case, the graph tells most of the story.
Regarding the differences you can't see on the graph:
- soundstage is slightly bigger and airier than both other pads
- easily the most comfortable pad I've used yet on SW01
Leather is closer to stock, but with the YAXI, everything is just better.
100% recommended.
