New Hidizs AP200 double DAC Android-based smart music player
mbwilson111
- Oct 13, 2016
Of course there will. The Chinese holiday has only slowed things down a bit.
Mortenhoe
- Jun 27, 2015
Mine sometimes pauses after 2-3 seconds playing, on the first track I play, right after I turned it on. I can just press play again. Seems wierd. I have gotten used to it. Started with 2.2Beta
mbwilson111
- Oct 13, 2016
I have noticed that when I first turn it on, the first track will begin very quickly when I press play, possibly cutting off a second ... or less. It is hard to say because it does not sound like a stutter or glitch. Everything will be perfect after that. I do play whole albums though and never shuffle.
- May 7, 2017
I got the same problem before that is when I plug my CIEMs the song automatically starts and stutters every time until I touch play then it plays the rest of the whole song. I am using beta 2.2.
cleg
- Oct 14, 2011
I've made a subjective video comparison of 4 mid-tier Android players (including AP200), may be it will be helpful for someone:
se7en7
- Jul 1, 2016
Does the AP200 have aptx and when you use it does it pop up on screen the same as x5 x7 3rd gen?
Thanks
Thanks
GR33dyblackie
- Aug 22, 2015
hi i just updated to 0.26beta (via the Hidizs QQ china group). dac usb-out still not supported yet, changelog states it support aptX. But im unsure how to verify that. any1?
- May 7, 2017
Have they sent out the new FW update 0.26 beta to USA group yet? Anyone?
Hi we will update the new firmware in the near few weeks,Sorry keep you waitting.Hidisz, hows the firmware update coming? We really, really need that
Thanks
From Hidizs
Starting to appreciate AP200 more and more. After collecting dust for the last two and half months, decided to give it another chance.
I did yesterday an extensive listening AB-ing between FiiO X5ii and AP200 and was surprised that during the listening tests started to strongly favor AP200. I don't use IEMs, hate sticking anything in my ears, so all the HPs were bigger. Due to the AP200's highish output impedance, it is important to use HPs with at least 32 Ohm impedance or higher. I've used some with 40 to 60 Ohms.
At first listening, FiiO X5ii produces bigger and wider soundstage, much bigger I would say. Also it is more warmish due to the Burr Brown (TI PCM) chip vs. Sabre in the AP200. But after a while, I've started appreciating more AP200'S outstanding clarity, more layering and more vibrant sound. What at the beginning sounded like a congested and narrow soundstage on the AP200, after longer listening came out as a focused and more precise imaging sound. The reverberation was more real than with the X5ii, middle voices were much clearer layered, and most important, the sub-bass went much deeper. This was very obvious when listening to Britten's Simple Symphony with a pizzicato (plucking strings) second movement where you could exactly follow the line of the double basses with the AP200 down to the lowest tones, with a real sub-bass rumble, where X5ii started to sound wooly and muddy.
Although X5ii sounds on the first listen warmer than AP200, it still sounds more digital or more artificial. After a few minutes of listening, it was easier to loose yourself and tap the foot with the AP200 than with the FiiO, where there was always some artificial aftertaste. Coming back to the FiiO after longer listening the AP200, everything seemed to sound blurry. After that I did some comparison with the xDuoo X3, which sounded thin and clinical compared to the AP200.
Listening to the music with a big dynamic range, AP200 didn't loose the substance when the music went down to very soft, while the FiiO and the xDuoo's X3 started to loose the color and sounded fragile at the low levels. I suppose this is thanks to the 32 bits digital volume control vs. 24 bits as found in FiiO and xDuoo. Lowering digital volume is causing reducing the bit depth, which leads to the signal truncation at low levels. With the 32 bits digital volume, there is more playground to save the resolution.
The main reason I bought the AP200 was to use it as a transport with a Mojo, listening mainly to Tidal. Still waiting the possibility to store Tidal's offline files to the sd card. This is, as much as I understand, solely in the hands of the Tidal app developers. The more important functions still waiting to be released are the dac-out and the line-out functions. These are however in the hands of the Hidizs' techs. Once this will be fixed, the AP200 could be a real winner.
Hi Djbobby
Thank you for your valuable sharing.
Thanks
From Hidizs
HiHey Hidizs: I wonder if Indiegogo campaign already gone? What would be the best way to order AP200 today?
You could order AP200 from Aliexpress.com or Amonzon.
Thanks
From Hidizs
Does anyone experience cutoff on the start of each song? I'm on 0.2.2Beta
Hi you could try to switch off "gapless playback"
Thanks
From Hidizs
- May 7, 2017
I enjoy the AP200 with Unique Melody Miracle which collected dust in months via Effect Audio Ares II cables. I am very happy with this combination that makes me listening to them almost every night. Now the Fiio 5X iii will be soon put on sale.
gugman
