New Headphone Stand
Aug 5, 2013 at 9:44 PM Post #526 of 546
I kind of like the look of this one.  And it looks like it's got a good curve for the headband.
http://www.amazon.com/Brainwavz-Gypsum-Headphone-Stand-Sizes/dp/B00D741DRK/ref=sr_1_45?ie=UTF8&qid=1375753356&sr=8-45&keywords=headphone+stand
Aug 13, 2013 at 7:53 AM Post #527 of 546
This took me 2 weeks to finish.  Hope this gets accepted on Amazon.  Will work on adding a drawer in front to house the electrical/power sockets so chargers for both the DAP and amp can be plugged onto the drawer.
Aug 17, 2013 at 10:15 PM Post #529 of 546
Amazing stand, man!
Aug 25, 2013 at 3:23 PM Post #530 of 546
Was able to pick up the older model Rubbermaid Hose Hook at Lowes for $15 CDN. It was almost perfect but I was super anal about the pressure points put on the headphone band like most people in this thread. So I slightly modded mine by adding a plastic piece from an old Verbatim DVD spindle.
I have a pair of Ultrasone Pro 990 and underneath the headband is a piece of foam. When placed on top of the grey holder on the Rubbermaid, it exerts upward pressure that will cause an indentation. To alleviate the pressure, I cut a plastic piece from the side of a DVD spindle and snapped it into the grey clasp of the Rubbermaid holder. The headphones now rest on top of the plastic piece, where the pressure is spread out across the plastic piece instead of the narrow hook area of the stock clasp.
This will work with other headphones as well for those worried that the clasp putting a permanent indentation in their headphone band.
Thanks OP for this great find.
Aug 25, 2013 at 3:59 PM Post #531 of 546
sp3ll...thats ingenious!
could you provide more details about the build? (materials/machinery, etc..)
Sep 12, 2013 at 7:12 AM Post #532 of 546
Pure wood save for the gooseneck and the brace. But that's the first of its kind.  I've made an evolved stand for now but still dissatisfied with its final outcome.  A more mature looking, more ergonomic and certainly lighter stand is in the works.
Here is the version 2 that leaves me still dissatisfied.
Nov 29, 2013 at 3:38 PM Post #533 of 546
Nice!
I will try this soon. I need a stand for my new HD598.
Nov 30, 2013 at 1:09 PM Post #534 of 546
Low budget listening station............
9"-10" Metal Bookend or Document Holder
5" Metal Bookend
1" Foam Pipe Insulation
Velcro
Rubber Feet
http://www.officemax.com/catalog/search.jsp?freeText=metal+bookends&search.x=0&search.y=0&searchText=Search+by+Keyword+or+Item+%23
http://www.homedepot.com/p/Armacell-1-in-x-6-ft-Tubolit-Self-Seal-Foam-Pipe-Insulation-OES11838/100565309?keyword=803014118101#.UpoibCf4wf4
http://www.homedepot.com/s/velcro+strips?NCNI-5
http://www.radioshack.com/product/index.jsp?productId=2103342
I already had everything except the pipe insulation.
The Sansa Fuze+ and Artcessories HeadAmp4 are attached to the 5" bookend with velcro, which is bent slightly backward for easy viewing.
The stick-on rubber feet are on the bottoms of the two bookends.
Dec 9, 2013 at 9:47 AM Post #535 of 546
Picked up the Rubbermaid Hose Hook from Home Depot for $14 (CAN)
Works well for my HD 598. I will try to upload a pic after work.
Feb 24, 2014 at 3:27 AM Post #536 of 546
http://www.digital-life.si/slusalke/avdio-dodatki/i_636_just-mobile-headstand-silver
Apr 12, 2014 at 7:21 AM Post #538 of 546
How did you do this man? It looks so good. Is it made of plastic, fiberglass, ? Either way, it's awesome.
Apr 21, 2014 at 3:29 PM Post #540 of 546
Home Depot one looks nice also.
I just got one from Lowes. Looks about the same. Very sturdy. $9.98
You can find it in the garage tool cabinet section. Kobalt Tools. All black cabinets.
www.kobalttools.com    11 1/4" high. The base is 7.3/4" wide. 5" deep. Weight 2 pounds. (1.98)
Walt
