The Bryston is one of the most neutral sounding amps I have ever listened to. Nothing colored with this amp at all. Most likely the reason why I ultimately sold it. Fantastic amp though.
New headphone amplifier from Bryston
- Thread starter Hardertaskthinking
Hi guys.
I wrote this review recently of the Bryston BHA-1, hope some will find it interesting:
THE HEADPHONEER - BRYSTON BHA-1 REVIEW (2019)
SilverEars
- Sep 18, 2013
What DAC was used? Ideal DAC was Gungnir Multibit.Hi guys.
I tested it with Hegel HD25, Violectric V800 and Audio-gd Master 7. I can imagine the Gungnir being a good match, the Bryston doesn´t seem to mind a DAC that leans towards the warmer side of the spectrum
SilverEars
- Sep 18, 2013
Although I haven't tried too many DACs, I do usually try two kinds of DACs as a test, and I think multi-bit and delta-sigma are good to test an amp. When I tried Hugo 2, delta sigma, the amp didn't put out hard attack for high-hat sounds, and was a bit smoothed off sizzles. So, it seems multi-bit was a successful pairing for the BHA-1, and if paired in such way, it enhances the performance significantly compared to if some random DAC was paired I take it. We can't be sure if it's really the DAC being 'multi-bit' with certainty as Ayre Codex sounded pretty much identical to Gumby to my ears. I'm thinking Ayre Codex is delta-sigma?I tested it with Hegel HD25, Violectric V800 and Audio-gd Master 7. I can imagine the Gungnir being a good match, the Bryston doesn´t seem to mind a DAC that leans towards the warmer side of the spectrum
omniweltall
- Nov 13, 2016
Schiit multibit would also maximize the BHA-1's staging and layering.Although I haven't tried too many DACs, I do usually try two kinds of DACs as a test, and I think multi-bit and delta-sigma are good to test an amp. When I tried Hugo 2, delta sigma, the amp didn't put out hard attack for high-hat sounds, and was a bit smoothed off sizzles. So, it seems multi-bit was a successful pairing for the BHA-1, and if paired in such way, it enhances the performance significantly compared to if some random DAC was paired I take it. We can't be sure if it's really the DAC being 'multi-bit' with certainty as Ayre Codex sounded pretty much identical to Gumby to my ears. I'm thinking Ayre Codex is delta-sigma?
Btw, the Bryston is proof that we should not trust the power rating that manufacturers provide. Looking at the power numbers, the BHA-1 is much lower than the Taurus and Master-9. Either Bryston underates the number or AudioGD/Auralic overrates theirs.
I found the BHA-1 in SE to be lacking but in balanced mode it came to life. One of the reasons I sold the Bryston actually. That and I found it boring. It is a very neutral sounding amp.
greggf
- Dec 16, 2006
I've been at this so long that I'm beginning to realize that the best gear, including the Bryston BHA-1 and the Pass HPA-1, * ARE * boring. Neutral stuff is neutral lol.
SilverEars
- Sep 18, 2013
Uh, ok? Boring means good? I can't put the HPA-1 on the same level as BHA-1. HPA-1 sounded a bit to Pass-y warm. Not my tea. Not neutral enough, I mean boring enough.I've been at this so long that I'm beginning to realize that the best gear, including the Bryston BHA-1 and the Pass HPA-1, * ARE * boring. Neutral stuff is neutral lol.
For me, it's not about neutral or not. It's about the right timbre, and HD800 doesn't sound like a meat grinder, and I get strong tight bass out of Sennys. I think 800's treble sounding like it does out of it is rare and unusual. It's an unusual amp. Typical solid state doesn't sound like that.
800's treble will usually sparkle at the tip and the degree will depend on the amp. I think I heard 800 do it the least out of the BHA-1. It smoothens such characteristic.
omniweltall
- Nov 13, 2016
The BHA-1 mates really well with the Senns (600, 650, 800). More than any Solid State I tried so far. Timbre is spot on. Brings the bass to life. And it doesn't sacrifice staging and timbre. This is one detailed SS amp.
Let's not compare SS with Tubes as they sound different. It depends on people's taste and gears.
SilverEars
- Sep 18, 2013
Who thinks balanced output is superior to single ended? I know I do. This is one amp balanced sounds obviously different from single ended. Is this a true balanced topology or not? Manual says balanced dual mono circuitry.
Yes, a balanced design will always perform technically better in balanced output. SE output from a fully balanced amp design is compromised by design and is only there for added convenience. However, I found the BHA-1 to sound very good in SE mode in many cases. It lacks some juice, obviously, but with many (but not all) headphones it was almost on par.
judomaniak57
my klipsch hp3 with a 25 ohm impedence and 98 db sensitivity sounded ok single ened. Balanced ,wow, whole different ball game. dynamic and fast with so much slam. totaly changed my mind on these headphones which i thought where only ok to what a totl headphone should sound like. Same goes for my focal elears
That is exactly what I meant. When I stated 'boring' I followed it up with why I found it so. As a very neutral sounding amp which many people will love, I as a tube guy find neutral as boring. That takes nothing away from a very well made, fantastic performing amp that is the BHA-1.
greggf
- Dec 16, 2006
Amish, exactly. Well said.
