New Forum Tips and Tricks!
Status
Not open for further replies.
May 5, 2017 at 9:07 AM Post #61 of 66
@mandrake50 I went looking for an easier way to change email notification settings on threads and there's a simple method accessible from the subscription page. You can check the box next to the thread and then move down to the bottom of your subscriptions. There's a dropdown menu in the bottom left (almost hidden if you have a lot of subscriptions) that will allow you to change email notifications. I just made a few changes with my test account and toggling between on and off was simple. See if that works for you and stops the notification emails.
Note: it did take several seconds for the server to update and apply the change, so you might have to wait a moment or two while it processes the request.
I wrote before I read this. I will give this method a try. It seems much easier...obviously.
May 6, 2017 at 12:12 PM Post #63 of 66
Thanks Axel. I have not gotten any email notification since turning them off using the method that you provided.
May 10, 2017 at 12:55 PM Post #65 of 66
hello, how do i update the title of the thread? thanks!
You won't be able to update the title of this thread, but you can change the title of a thread you started using the Thread Tools dropdown at the top.
Status
