New!! Cavalli Audio Liquid Crimson Amp
- Thread starter runeight
eskamobob1
- Nov 16, 2011
Some internal pics of mine
eskamobob1
- Nov 16, 2011
Cavalli Liquid Crimson Voltage change
240V wiring:
120V wiring:
Pins:
240V wiring:
Pin 1: empty | Pin 2: white |
Pin 3: empty | Pin 4: blue |
Pin 5: black | Pin 6: brown |
120V wiring:
Pin 1: white | Pin 2: brown |
Pin 3: black | Pin 4: blue |
Pin 5: empty | Pin 6: empty |
Pins:
Ham Sandwich
- May 22, 2006
Nice! It has a good home.
How does the Abyss Dianna sound with it? I'm assuming the sound of the amp pairs well with it. Abyss has a Liquid Fire and Liquid Gold. And used the Liquid Fire as one of their amps when designing the original 1266. So I'm guessing the Abyss headphones will pair well with the Cavalli sound.
tenisnut333
If the original Cavalli Liquid Crimson is engineered/designed as Single-Ended hp amp, then how can it also have a Balanced hp output? Please explain. Thx.
paradoxper
It's there for convenience not as fraudulent marketing.If the original Cavalli Liquid Crimson is engineered/designed as Single-Ended hp amp, then how can it also have a Balanced hp output? Please explain. Thx.
It's relatively easy to generate a balanced output using phase splitters, whereby you're essentially creating a phase inverted (180º) copy of the signal. This kind of a balanced output won't have the benefits of a fully differential amplifier of course, but as @paradoxper said, it's a convenience for those who have invested in balanced cables for their headphone collections. Alex implemented thoughtful little things like that all the time whenever he designed an amp.
tenisnut333
Thanks for the very brief but well-explained concise answer, much appreciated!It's relatively easy to generate a balanced output using phase splitters, whereby you're essentially creating a phase inverted (180º) copy of the signal. This kind of a balanced output won't have the benefits of a fully differential amplifier of course, but as @paradoxper said, it's a convenience for those who have invested in balanced cables for their headphone collections. Alex implemented thoughtful little things like that all the time whenever he designed an amp.
Ham Sandwich
- May 22, 2006
The 4-pin jack is wired as single-ended output. Wired as if it were like a 4-pin female to TRS male adapter cable.
It's a convenience jack. So you can plug in headphones with balanced cables without needing to use an adapter or swapping headphone cables. Most people with a Crimson or Glass are also going to have another amp that is probably balanced. And the convenience 4-pin jack on the amp allows you to plug in headphones with a balanced cable.
The 4-pin XLR jack is also a better headphone jack than the 1/4" TRS jacks. Better connections, and no chance of causing shorted connections that can happen as you plug in a TRS style jack.
The Cavalli Tube Hybrid amp sold through Drop also has a 4-pin XLR convenience jack that is wired as a single-ended output. The 4-pin XLR jack is electrically identical to the 1/4" TRS jack. Both single-ended.
