NEW - Campfire Comet and Atlas
173 174 175 176 177 178 179 180 181 182
184 185 186 187 188 189 190 191 192 193
  1. Luhar
    Just bought the Atlas in a private sale. Anyone have the IMR R1 to give a brief comparison against the Atlas? not in the same price tier, but would like some opinions
  2. Wheel Hoss
    Picking up the Comets next week. Thoughts on the tips? This will be my first foray into IEMs . . .
  3. davidcotton
    Depends what you get with them. Some have spinfits and others have Final Audio E which are popular on headfi.
  4. Wheel Hoss
    They come with different tips? Why is it?
  5. Luhar
    Anyone have experience with atlas + custom tips?
  6. Jackpot77
    I have the R1 and the R1 Zenith - which one are you referring to?
    Also, I use Custom Art custom silicone tips on my Atlas - they give a superb fit and a nicely balanced (for a basshead IEM) sound. Not particularly expensive, either.
    Luhar likes this.
  7. Luhar
    The original R1
    Thanks for your reply
  8. audio123
    zombywoof and Carlsan like this.
  9. Carlsan
    Good review, informative and honest.
    Did you mean to say in your conclusion "The Solaris is a musical sounding cable that is able to provide an impactful bass expression, vivid midrange and extended treble ... ?"
    audio123 likes this.
  10. audio123
    Thank you, it was a typo and already edited. Cheers! :)
  11. viatraco
    Is BA driver good secured in Comet ? I mean protected from dust, moist, earwax ? What is underneath of steel "frame" ?
  12. theveterans
    The BA is definitely protected from those three especially moist and earwax. Maybe dust can accumulate but if stored in carrying pouch all the time, that shouldn't even be a factor.
    The TAEC chamber is underneath the steel nozzle, and that replaces the narrow tube that is typically seen with BA drivers.
    Dobrescu George and viatraco like this.
  13. GitBash
    Is it possible to use the Atlas straight out of a phone?
  14. Rockwell75
    Yes it's not that hard to drive.
  15. GitBash
    Thanks for the answer.
