digitalzed
- Sep 14, 2012
I found this short video on how to detach and attach MMCX cables very helpful.
Enjoying my Atlas! Comparing to my previous best headphones B&W P7, the closed back P7 felt muffled, whereas Atlas felt more open and 'real', maybe that's what folks talking about when they talking sound stage? The Atlas is much louder as well, had to use lower volume on my DAP.
Interesting thing is while doing thing listening to music, I will be attracted by the music and paused whatever else I am doing to listen more attentively.
Now I am wondering should I get a balanced cable for the IEM. First thing though, I am not quite sure how to remove the stock cable. Don't want to brute force it, these are not cheap man .
So, I just tried these tips today. So far the comfort is unmatched!
In terms of change in sound signature I would say that it adds warmth while at the same time making everything even more energized! There is added body to the bass (I think some might say that there could be a bleed into the mid-range, but this might me being crazy). You can really feel a rumble with these tips!
I found this video really helpful with attaching and detaching MMCX cables.
Decent balanced cable for Comets without breaking the bank please? Tried the brainwavz one from amazon uk and it's nasty (it was only £15). Don't want to go nuts with the pricing though. It's mainly the mic and lack of chin slider that I don't like about the original!
The campfire mmcx connectors are really nice and thus really firm. I usually get my fingernails between the iem and the connector and try to apply even, kinda-pinching force to pull it up out of the IEM. Otherwise if you can get a good grip on the connector itself go ahead and pull hard (just NEVER the actual cable).
As for balanced, I find it helps channel separation a good bit and adds a little to soundstage for most of my headphones, but YMMV. Does your DAP have a balanced output?
Sounds good, thanks! Just figured out this type of cable is called MMCX, not litz as I originally assumed, also ran across that YouTube video yesterday.
Good information. I was thinking Litz refer to the whole cable, then thought MMCX is it. But looks like there is quite some more aspects to be considered when choosing/ordering a cable, like the MMCX connector, single end or balanced, etc, etc.MMCX is a type of connector; Litz is a type of braiding.
Going to try a Brainwavz candy cane cable that cost $45 to see how the balanced output on my DAP sound.
According to my DAP (A&K SE100) spec, the main differences seems to be:
output level: balanced 4.1 Vrms, unbalanced 2 Vrms.
signal to noise ratio: balanced 123 db @1KHZ, unbalanced 122 db @1KHZ
THD-N: balanced 0.0006% @1KHZ, unbalanced 0.0007% @1KHZ
Great to hear! Do you have recommendation for the brand of balanced cable?The cable that comes with your Atlas is a really good cable but I found running a balanced cable further improves the sound.
So I actually ordered the same cable that comes with Atlas, except terminated in 2.5 mm balanced. It's available on ALO Audio's website as the Silver Litz, and you select your connector preference before adding it to your cart.Great to hear! Do you have recommendation for the brand of balanced cable?
