raoultrifan
I think it's v2.24, the one with Win8 in the name. It has ASIO and a small XMOS audio control panel in Systray (bottom-right).
It's 2.2 for music listening, is that OK?Only you could determine this and it depends on your system and preferences. Though, likely the Burson will sound better on DAC duty than the Onkyo. You just running a 2CH setup? The Burson only supports this.
It's perfect even if you install driver form Burson it will show the sound and mic working good right please check your output for audio and mic is selected for Burson play post if you have any problemHello,
I bought that Burson Play for Xmas and i have problem with Xmos !
I lost many hours to check and obtain the right drivers, but nothing work !
When i read that -> http://www.canever.eu/1/upload/driver_installation_for_windows_users_21apr2016.pdf
I can see that the driver from burson "Burson_UsbAudio_v4.59.0_2019-04-02_setup.exe" have missing steps.
This is what info i get for my devices
I'm under Windows 10 home 64
Any solutions ?
All I did was go to Burson site and download the driver there, install it and done. Windows 10.Hello,
Any solutions ?
Hello,
Any solutions ?
If output works its perfect nothing to worry with itAll I did was go to Burson site and download the driver there, install it and done. Windows 10.
But you have "Play" or "Playmate" ?All I did was go to Burson site and download the driver there, install it and done. Windows 10.
i'm under 1809Hello!
I had before Burson Play and I had the exact same problem, tho with I had Windows 10 Pro 64bit. Try to upgrade your Windows 10 to 1909 version, and let the WIndows to search a driver for it. For me this worked well under 1803 and 1809 versions.
i'm under 1809
It works when you play ASIO in foobar or jv playerBut why i have not that working:
And What is this XMOS DFU who have no driver at all ?
i'm under 1809
