New Audio-gd R7 (R2R 7) & R8 Flagship Resistor Ladder DACs
post-13814727
Post #586 of 6,062
FredA
@FredA Thanks. Currawong’s pictures looks like one board in a stack with a metal shield on top. Double sided circuit board with parts on both sides makes sense.
Dumb question.,, How is DSD implemented in R2R 7?
There are not so many ways to do this. A subset of the the ladder has to be used to generate signed pulses at a very high frequency, depending on the dsd format. These pulses are simply low pass filtered with hardware . But i am not an expert in that domain, i am just stating how i would do it.
post-13815549
Post #587 of 6,062
FredA
Listening to the Beach Boys for the second time with the r2r 7. The first time was in the first few weeks of ownership, Those guys were into some serious stereo effects (i get sound bursting from everywhere with a quite spectacular 3d effect). The most recent track's recording quality is quite impressive. The r2r 7 is like a good wine. It ages well. Sounds better this time and also this confirms my matching effort paid off with with excellent bass and better balance.
post-13815988
Post #588 of 6,062
barbas
Montevideo, Uruguay
Montevideo, Uruguay
Is there anyone out there that happens to like R2R 7 in NOS mode rather than OS?
post-13816001
Post #589 of 6,062
gk2013
Yes, one of my friends (no forum member) uses the R2R 7 in NOS mode. He prefers NOS above Oversampling mode.
post-13816018
Post #590 of 6,062
barbas
Montevideo, Uruguay
Montevideo, Uruguay
I just bought an R2R 7 from Magna Hi-Fi (btw, can't be happier with Joss customer service, this guy certainly knows his job!) replacing a Ref 5.32 converted to a NOS 5 Amanero. I always preferred NOS mode over OS and by a big margin, that's why it was a real surprise reading that everybody seems to like OS x8 mode over NOS in R2R 7, including Joss. I'm still burning the Dac and I'm not in the mood for playing with jumpers already, hence the question over here.
By the way, first 300 hours of burn-in took place in my brother's setup (Avalon Indra, Vitus SIA-025 and Vitus SCD-010) and once the AGD achieved 200 hours of burn-in, it was clear to me that it surpassed in every possible way the SCD-010 Dac, a unit costing 6-7 times more than Kingwa's baby boy.:astonished:
Will comment more accurately in a few days after finishing burn-in period.
Reactions: FredA
post-13816038
Post #591 of 6,062
FredA
Not surprised. Looking forward to hearing your feedback.
post-13816201
Post #592 of 6,062
Fukuoka, Japan
Fukuoka, Japan
Website
www.hear.reviews
Which NOS mode do people prefer?
post-13816288
Post #593 of 6,062
barbas
Montevideo, Uruguay
Montevideo, Uruguay
post-13817600
Post #594 of 6,062
Articnoise
Sweden
Sweden
Your brother has one nice audio system. Did he also think that your R2R 7 sounded better than his Vitus?
post-13818002
Post #595 of 6,062
barbas
Montevideo, Uruguay
Montevideo, Uruguay
post-13823635
Post #596 of 6,062
christianvogel
Amsterdam
Amsterdam
With NOS 5 I preferred Mode 3
My experience is that NOS only sounds better if you have a good jitter-free digital source. Oversampling seems to mask jittery harshness, smoothing it out. However with a very good digital source, NOS to me sounds better.
For example, with a raspberry PI powered by battery over spdif coax using a hifiberry Digi+ board, oversampling sounded better. Then I upgraded the source to a Mano digital streamer over I2S over an audio quest chocolate HDMI cable and suddenly NOS is a lot better to me.
My favourite NOS mode so far is mode 2 (FIFO). This was only the case after upgrading to the Mano, before that I preferred mode 3 (smoother sound).
This is with the firmware I got the R2R-7 with. However the new smooth firmware was really a remarkable upgrade (completely opened up the top-end of the sound, which sounded weird before), and I need to try the modes again.
PS: @Currawong: when reviewing the R2R-7, I recommend to try to get a source like the Magna Mano or Sotm sMS-200 ultra to loan, just to experience the effect. It is really remarkable what impact the digital source has on these NOS dacs...
Reactions: doak
post-13823647
Post #597 of 6,062
barbas
Montevideo, Uruguay
Montevideo, Uruguay
Hi Chris, what was your experience regarding PLL?
post-13824196
Post #598 of 6,062
christianvogel
Amsterdam
Amsterdam
Hi @barbas, I tried turning the PLL on, and that gave me worse performance, even with the PI, so it has remained off since.
I do hope mr. Kingwa will enable us to do these settings through the front-end buttons instead of jumpers through a software update... the amount of times I have had to disconnect all, carefully slide the DAC out, open, change a DIP, and reverse the process...
Mr. @Kingwa, I have this suggestion for a menu system for the R2R-7:
entering and exiting settings mode:
- pressing both channel selector buttons for 3 seconds: go into settings mode (flash display)
- pressing both the same way while in settings mode: exit settings mode to normal mode, applying any changes
in settings mode:
- pressing the left channel select button: cycle property to set (show a flashing number)
- pressing the right channel select button: cycle value for the current property (show the value for a second, then switch back to the flashing mode number)
values for each setting:
0: oversampling switch. 0=off, 1=on
1: select OS/NOS mode. In NOS: 1, 2, 3. In OS: 1=OSx1, 2=xOS2, 3=OSx4, 4=OSx8
2: PLL mode. 0=off, 1=on
3: dithering. 0=off, 1=on
This has the added benefit that no-one will have to open the DAC anymore, so less warranty issues...
post-13824214
Post #599 of 6,062
FredA
Hi Christian.
Are there between the 3 nos modes ones that are synchronous, meaning the clock from the i2s signal is taken as is (no reclocking)? This is a possibility with the nos7, if i am not mistaken. I have an excellent i2s source so i will try NOS soon, just curious.
post-13824220
Post #600 of 6,062
Articnoise
Sweden
Sweden
I agree that NOS is more sensitive to upstream jitter and noise than oversampling. That was the main reason oversampling was invented.
Reactions: astroid
Users Who Are Viewing This Thread (Users: 1, Guests: 3)
