New Audio-gd R7 (R2R 7) & R8 Flagship Resistor Ladder DACs
Discussion in 'High-end Audio Forum' started by Currawong, Jun 30, 2017.
319 320 321 322 323 324 325 326 327 328
330 331 332 333 334 335 336
  1. UsoppNoKami
    My R7HE has arrived. Lucky with the timing of my order, Kingwa uprated the transformers spec last month for extended operating duration. Will reconfigure my gear and rack soon, just pulled out the Master-11S for now but it will go back in and both DACs will be fed by the Singxer SU-6. Happy days ahead , loving the sound of the R7HE already :)
    motberg, Tango Sierra and FredA like this.
  2. DACLadder
    @Chopin75 I think you are correct on the N100 only doing up to DSD128. That does indeed suck if the $8,000 streamer can't do DSD512. Even the W20 ($17,999) only appears to do DSD128 max. Seems their high-end customers would be demanding it and more!
  3. DACLadder
  4. UsoppNoKami
    :dt880smile::beerchug::beerchug::beerchug:
  5. JAGS
    Cool - enjoy!
    *This looks interesting https://www.audioenzo.nl/audio-gd-r-7-componenten-upgrade/ (translate to English required :L3000: )
  6. UsoppNoKami
  7. FredA
    Welcome to the club! I have the old transfo spec but i can tell you you won't regret it. Those wondering which is the best dac under 10k, i would venture to say the r7he. Forget about the Terminator, it has been terminated. :)
  8. FredA
  9. DACLadder
    Wonder no longer. I’ve been using the JCAT PCIe USB board for about 4 years. Nice feature you can plug in linear +5V to power USB ports. But the Aurender sounds better. Allo Usbridge sounded better also. And the JCAT board works flawlessly as far as operation where the PC USB ports do not work with every device like the Altera Blaster.
    comzee and Turdski like this.
  10. remoss
    Yep :) And remoss = AudioEnZo. I have asked the admins here several times to change my nickname, but no luck....
    UsoppNoKami likes this.
  11. gk2013
    Got the Magna upgrade too + internal i2s silver wiring in cotton; unbelievable its incredible. The DAC sounds incredibly spacious and clean now. Raw edges have completely disappeared.
  12. remoss
    @gk2013 it's really a great upgrade indeed. The normal upgrade is on the circuits of the DA-7 boards, but i have the silver wire mod also and some extra circuit adjustments on the digital mainboard. I dare to say it makes as much difference than the upgrade to Accusilicon clocks!
    FredA likes this.
  13. Il Cuffiotto
    Very interesting upgrades...do you know if they are sold as diy kit? I need to write to Magna...I don't like to ship my 19kg 7HE!
    Hmmm
  14. DACLadder
    That’s a great DIY idea! Throw in a roll of silver wire to complete the upgrade. Probably remove the digital board for the cap change anyway. Replace the wiring when re-installing the board for a neat installation.
  15. Il Cuffiotto
    Would be great to have some indication to understand exactly what electrolytics need to be changed...that's Magna's secret for best result. I suspect they will say "hey man! Ship me your dac and we will do it for you!".
