I checked the web site for Aurender, and its idea is similar to what PC builders for music try to do. It uses a Cache technique where I presume music is temporarily loaded to be played and is away from the HDD. I presume the cache is in the less noisy SSD ? This I suppose would isolate the noise of the HDD by putting music to be played in separate SSD. I am not sure where the Software for playing music is if one were to play the music in the Aurender instead if using NAS, roon etc, but presumably it is also in the SSD ?
My PC does not have HDD and euphony I use (in the SDD) also uses the Ecache to have music loaded into the SSD. I would attach my external HDD. load the music to the Ecache in the SDD and then I would detach the HDD altogether (though I use a USB filter that seems to eliminate most of the noise coming from the HDD anyway, as I don't hear much difference now with HDD attached vs detached).
Is the aurrender using an uttracap LPS ? (I think I saw it somewhere)
I presume it has a nice USB bridge with a separate clock with separate LPS ??
Are the other outputs e.g Coax,toslink also clocked ?
I've always wondered what advantage a music server would have over a PC setup, for example I have a lower end intel N4200 passively cooled 11.6" display laptop with an internal SSD feeding my R8 via USB, attached to the laptop is a 2TB external SSD which has all my music on it, if I wish I can even disconnect the power supply of the laptop and have it run on battery, which I haven't tried yet but I doubt I would hear a difference, it runs linux headless and uses MPD which I control from an app on my phone.
