audionewbi
- Jan 24, 2010
The major downside is 2.5mm jack.
A friend of mine told me the 3.5 mm jack is arguably better than 2.5mm so no worries there however for a dap of that size 4.4mm is feasible. I get why designer like 2.5mm it takes less space.
Head over the dpx1 thread and ask the user of dpx1 regarding their view on 2.5mm. Before Sony DAP I came to the conclusion if a device can't get the 3.5mm sound right balance is just another gimmick when it comes to portable DAPs. HUGO made me be sure single ended has a lot more offer soundwise however Sony made me feel maybe balance on portable usage isn't just a gimmick.Have you ever had a 2.5mm jack fail? I haven't. 2.5mm is a standard, it works, and its a lot more sensible when the push is to have smaller devices. Sony decides to buck the trend and comes out with the 4.4mm and everyone swoons over it. The SQ will not be affected by the jack size. It's typical audiophile reaction to a problem that doesn't exist.
- bigger = better
- more drivers = better
- newer = better
- more expensive = better
Except mostly thats not true. And in this case I hope the 4.4mm just fades away. Its an answer to a problem that isn't there.
Do you have the new firmware that has the playlist and file delete support? Or the old firmware?
This has to stop.Head over the dpx1 thread and ask the user of dpx1 regarding their view on 2.5mm. Before Sony DAP I came to the conclusion if a device can't get the 3.5mm sound right balance is just another gimmick when it comes to portable DAPs. HUGO made me be sure single ended has a lot more offer soundwise however Sony made me feel maybe balance on portable usage isn't just a gimmick.
Good for power, and may have different output impedance by design - but generally when you volume match - most of the balanced DAPs and DAC/amps I've tried sound the same (and measure the same - to the point of audibility anyway).
Hey Soundblast75,Anybody seen L6 yet?
This would be very nice, thank you.The sound is incredibly good. More smooth and lush approach in general sounding. Build quality and software is up a notch from comparing to L5 Pro. I can post some photos and mini review if u want.
