Hello I am new to high quality audio so please forgive my ignorance.
I am looking to get headphones, dac, and amp. My usage is 90% gaming 10% media consumption(youtube, netflix, twitch, etc). I want headphones that are closed/noise canceling. I also want them to be very good for competitive gaming(hearing footsteps locations etc) and also good for everything else if possible. I also would like a dac or amp with bass boost so when not gaming I can add it to get some bass for music etc. I will be using this setup for PC and consoles(NES-next gen 2020/21). I want a dac with optical/toslink in and analogue in. I would prefer a dac with ALL inputs so I can get one that will last a very long time and be universal/work with everything from old to new. I would like recommendations for everything. Budget isn't really an issue, BUT I don't want to be spending a ridiculous amount because my ears may not be good for the really really expensive stuff. I am basically deaf because I have had a sound system in my car with 2 12" subs blasting for 12 years. Please suggest headphones, dac, amp. I want really good stuff that will last a long time. I was told to get a dac and amp separately because it gives me more options. Budget is $300-500(or less) for everything, the cheaper the better honestly(but still want good products). Can be convinced to get more expensive products, but would need validation as to why.
Headphones I was suggested: Sennheiser HD280PRO & Audio-Technica ATH-M40x
Thank you for you help/suggestions.
