Need recommendation for noise isolating over-ear headphones
post-12197263
Thread Starter
Post #1 of 9
AviP
What headphones would you recommend if I need:
1. Good noise isolation
2. I prefer bass heavy
3. Over-ear
4. Under 120$ (I can be flexible if it costs more)
5. Will be used at my desk at work so portability isn't really a concern.
6. Sound quality (duh)
As a side question, how much better would the isolation of IEM's like Shure SE215 be?
Thanks!
post-12197357
Post #2 of 9
SeaWo|f
Website
www.youtube.com
Bassy closed headphones? Sound like dt770 pro to me. I have a pair, they are super comfy and i think they offer exactly what you are long for
post-12197430
Post #3 of 9
AviP
How many ohms?
How would that affect the bass?
post-12197450
Post #4 of 9
SeaWo|f
Website
www.youtube.com
I bought the 250 ohm as I have a nice dedicated HP setup. And I'm not sure how the 250 and 80 compare bass wise someone else will have to comment on that.
post-12197462
Post #5 of 9
AviP
How about the DT 770 M?
That seems to be the same as the pro with an extra emphasis on isolation.
post-12197482
Post #6 of 9
SeaWo|f
Website
www.youtube.com
I might be wrong so someone correct me please but i think the main change with the m is the ear cup material. Leather and synthetic leathers isolate more than velour which the normal pro has, they might also change the ear cup padding too.
I hate leather and synthetic leather on my ear cups. It gets hot, it sticks and doesn't wear well over time. But that's my preference
post-12197527
Post #7 of 9
AviP
Thanks!
I'm going to look into the dt 770 pro 250 80 ohm
post-12197996
Post #8 of 9
fakeblitz
Hi, sorry to barge in, but i create a very similar thread, but no one replied.
I found this
http://www.amazon.co.uk/Beyerdynamic-DT990-PRO-Headset-250/dp/B0011UB9CQ/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1451231551&sr=1-1&keywords=Beyerdynamic+DT990+PRO+Headset+-+250+OHM
Not sure how good, since they are about 3 year old... same goes for the 770
Also a good read
http://www.head-fi.org/t/513393/guide-sonic-differences-between-dt770-dt990-models-more
post-12199279
Post #9 of 9
AviP
I found this
Also a good read
Thanks for the link comparing the different Beyerdynamic models, it was very helpful
