Need OTG [USB DAC] and charging solutions for Android phone at the same time
Nov 13, 2016 at 2:32 AM Thread Starter Post #1 of 2
LajostheHun
Hey guys not sure if this is the right place, but basically I wanna use my Android devices hooked up to my TEAC UD 301 DAC which of course works fine with my OTG cable but I wanted to keep the Android devices being charged at the same time. I've seen such cables demonstrated , but none with a DAC. So I wondered if any of you using such set up and if yes what cable/hub you recommend based on experience. Thanks!
This was one of those cable I've seen:
https://www.amazon.com/Adaptor-Cppslee-Charger-Adapter-Connector/dp/B01LXOJU3W/ref=sr_1_1?ie=UTF8&qid=1478975239&sr=8-1-spons&keywords=micro+usb+hub+otg&psc=1
Nov 25, 2016 at 7:29 PM Post #2 of 2
I'm also looking for solution relating to charging smartphone and using USB DAC (by OTG) at the same time. Cables/splitters available on the market do not allow the charging of source (smartphone), only other devices connected by OTG.
