need help with Lehmann Black Cube Linear
Jan 1, 2008 at 3:38 PM Post #3 of 7
Originally Posted by Mazuki /img/forum/go_quote.gif
Can someone who owns this amp kindly take a macro picture of the bottom of the amp? Thanks
Here you go!
Jan 7, 2008 at 8:13 AM Post #4 of 7
The sticker on the bottom of my black cube has worn off and don't know how to set the gain switches.
Thanks
i'll save you from the trouble, i'll buy the amp from you!
Feb 25, 2008 at 8:29 AM Post #5 of 7
Dear Mazuki,
with nearly no time for me to lurk around at headfi at the moment I suggest to use email to contact me next time.
The settings are
Both switches off: 0dB gain
Switch 1 on: 10gain
Both switches off: 20dB gain
The settings can also be found in the manual if I remember it right. If you lost yours I can send you a new one as a PDF
All the best from Germany
Norbert
Apr 18, 2010 at 9:02 AM Post #7 of 7
How long should you run in the Lehmann linear headphone amp? Mine sounds way too smooth! Ps help.
Originally Posted by norbert:lehmann /img/forum/go_quote.gif
Dear Mazuki,
The settings are
Switch 1 on: 10gain
Norbert
