need help with flaskMPEG
post-225507
Thread Starter
Post #1 of 2
recephasan
Hi all,
I'm using flaskMPEG to make copies of my DVDs.
I have a problem.
I seem to be able to tackle video compression but have problems with audio.
The only options I get under the 'Audio Compression' are :
DV Audio - PAL
DV Audio - NTSC
PCM
and PCM options are 48kHz (all), 8/16bit, mono/stereo.
well, I have loaded CD'n'GO so I have dlls installed for mp3, but do not see them among the options.
since this is an audio problem, I thought it's suitable for this forum
1) how can I get compressed audio using flakMPEG?
2) (less important question) what iDCT do you guys use for Athlon XP (2400)?
Thanks in advance
post-225667
Post #2 of 2
grinch
Cognac....icky.Scotch....icky.Vodka....
flaskmpeg sucks. use cce and ifoedit.
www.doom9.org is the prime place to find info on what you're doing. i *highly* recommend it. do not go anywhere else.
p.s. if you're backing up a dvd, you want to use the original ac3 audio. unless of course you mean making an svcd/divx backup or something..
