Oculis
- Oct 7, 2015
Up till now I used an integrated sound card on my computer connecting a set of speakers to the rear of the computer and headset to the front. Then splitting out the front and back into two separate audio sources and selecting front audio (headset) for applications like used for communication and read audio (speakers) for listening to music. I loved the ability to switch my music to headset with a click of a button and all that stuff when needed.
The problem now is that I've bought a decent pair of headphones to replace my "gaming" headset and now with less overwhelming base and clearer sound I hear a fair amount of noise from my front audio input. I've tried switching to rear audio and it does help but the same problem with noise transfers to speakers then. So I decided on getting some sort of external audio source to solve this issue and I can't decide what are some of the best options for my use case?
My first thought was getting Audioengine D1 but I soon found out that I can't really use it the way I want because it actually mutes the RCA output as soon as you plug in headphones in the front of the DAC.
So could anyone suggest some setup option that could achieve the convenience I want while providing decent sound quality. Should I just use two separate DAC's for speakers and headphones? If so, than any suggestions on which ones? Or maybe just buy a sound card that actually has the capability to attach both to the back? Or is there some device on the market with such capabilities?
P.S.: While I don't mind external devices for this task, I'd prefer a setup that isn't too bulky if possible.
