Need help on RKV tube rolling
post-218189
Thread Starter
Post #1 of 9
Dnic
Dear all RKV owners,
I want to find some tubes for backup the stock PoLamp tubes in RKV. Do you have experience on using other PCL805 tubes and how they sound? Many thanks.
Dnic
post-219315
Post #2 of 9
ServinginEcuador
Founder of the Head-Fi Pay-to-Post Program.
Dnic,
Thsi amp seems to have little info on tuberolling here on the site, but try doing a search from HERE on the words RKV and tuberolling. Illoked yesterday and only found Hirsch's recommendation about a 7308 series tube!
Happy hunting!!!
post-219360
Post #3 of 9
88Sound
Dnic,
I've tried Mullard tubes in my RKV, the differences between the stock Polamps and Mullards are very slight to non existant. I like this about the RKV, the only tubes I can find are under $6 a piece.
post-219370
Post #4 of 9
Hirsch
Why is there a chaplain standing over his wallet?
Originally posted by 88Sound
Dnic,
I've heard both the Polamps and Mullards on Dusty Chalk's RKV, and IMO the differences are minimal. I know that there are Amperex PCL85's out there, but the trick is to find them...
post-219526
Post #5 of 9
acidtripwow
I've had no luck finding the PCL805 tubes anywhere. It seems there is no tube rolling for the RKV. You better like the stock tubes because you're stuck with them.
post-219571
Post #6 of 9
Jan Meier
King Corda
Member of the Trade: Meier Audio
Dear Headfellows,
I discussed tube-rolling with Mr. Becker (the manufacturer) extensively. According to him the sound of the RKV is very insensitive to the tube used. The reason is the very low distortion this amp has (unlike most other tube amplifiers).
People searching for tubes can contact me. I can provide both Polamps and Telefunken tubes.
Cheers,
Jan
post-219794
Post #7 of 9
kelly
Herr Babelfish der Übersetzer, he wore a whipped-cream-covered tutu for this title.
I've found it to not matter on the few tubes I've tried and the Polamps to be the best by some tiny margin that may be more attributable to tube burn in.
Jan
Have you had opportunity to test out Telefunkens in the RKV? I'd be interested in your opinion of how they compare to the Polamps or if you hear a difference at all.
post-220899
Post #8 of 9
Dnic
Your feedbacks are great.
What I will do is ordering some Telefunken PCL805 from Jan if they are at the price that Jan had quoted to me. Very reasonable.
One HK tube supplier quoted Valvo tube for $25 @ and I rushed out to the door.
Hirsch,
Is the Amperex PCL85 interchangable with the PCL805? I know little about tubes.
post-220997
Post #9 of 9
Hirsch
The PCL85, PCL805, and 18GV8 (or is it VG8? I never remember) are the same tube.
