It's taken a while to get over the Atrio MG7, the bass was truly out of this world. The XBA-H1 is cannot really be described as a bassy IEM when compared to the Atrios, far more balanced. The sound of the hybrid drivers is really something special, all the bass rumble that's missing from the usual array of single or dual BA IEMs, and the balanced signature and lack of obvious flaws that usually plague the cheaper dynamic IEMs. The bass here can be described as above average, only a few DBs higher than is strictly "audiophile", quality is quite good, tracks with multiple bass lines are not muddled or lacking. Dubstep sounds excellent, I always thought this kind of music would be better suited to the insanity-crisis level of sub-bass of the Atrios, but now I realise it was too much. Also, the bass doesn't intrude where it shouldn't, jazz piano and strings sound as they are supposed to, really surprised with this, I can't hear any bleed into the mid-range. Metal and hard rock is perfect, I can't stop listening.
It's tough to review the mids and highs, there simply isn't much to complain about. There are no sharp peaks, no recessed mids, no harshness. Instrument separation is very good overall, maybe some room for improvement in the highs. Detail retrieval is excellent, this definitely due to the BA driver, no muddiness or veil here. The dynamic driver is very well integrated, this isn't a BA+subwoofer deal (remember the super.Fi EB?), it's as if there is no crossover at all. Soundstage is pretty good, not overly broad, but intimate. Definitely a "front row" presentation.
I'm really, really impressed with the signature overall, I can't believe how far budget IEMs have come. I tried really hard in the past to love BA's, tried nearly all of them, the XBA-3 came close but still sounded unnatural and strained. The XBA-H1 sounds effortless, and
correct. I'm already looking to pre-order the H2 and H3!
There is no doubt about it, the Atrios are only mildly bassier than the XBA-H1, not the earth shattering amount I had imagined (aural memory is quite poor). The XBA-H1s on the other hand are
much more detailed than the Atrios, it's really quite substantial. I can't believe I listened to the Atrios for 6 months and didn't notice how much was pushed into the background. I think I subconsciously accepted the compromise for the price and level/quality of bass, which to be honest is still second to none (in fact I came back to the Atrios after selling back in 2011 because I couldn't find anything better). The H1 still rocks pretty hard in the bass department, it
should be enough for bassheads, but I cannot say for sure, it depends on how much bass you want.
If you are choosing between the two, and one isn't heavily discounted for some reason, go with the XBA-H1.
This will be the end of the Atrio comparison, they are
up for sale here. I cannot pretend that they have the same value after trashing them as above, so I have cut the price to less than half retail, only £60 delivered for two day old Atrios, in the UK they are normally £125.
I'm looking seriously at the H2 and H3, so I will update soon if/when they arrive.
