Need help for DAC software
Mar 5, 2017 at 12:15 PM Thread Starter Post #1 of 6
rizzotti91
Hello, I'm going to buy a DAC to replace my Xonar U/.
Actually, with the Xonar U7, I'm using the Dolby Home Theater v4 software to equalize the front-output, to normalize the sound (this is a must in for watching videos) and to enable virtual surround with headphones while I play videogames.
When I need to listen to music whit my cans, I disable, with a simple click, the Dolby software and use Equalizer APO that is configured to work with the headphone output of my sound card.
I think that the Dolby software will not work with other DAC (such as Modi 2) and I found the Razer Surround software for virtual surround and for volume normalization, but the problem is that you need to enable virtual surround to use volume normalization, so if I just want to watch a video with my 2.1 speakers and no virtual surround (I don't like it but videogames) I can't.
My questions are:
1) How can I replace the Dolby Home Theater v4 software? I really need a simple equalization, volume normalization and, possibly, virtual surround;
2) Is there a way to disable/enable EqualizerAPO on the fly without restart the pc?
Thank you in advance and excuse me for my imperfect english.
Mar 6, 2017 at 8:02 PM Post #2 of 6
No one can help me?
Mar 6, 2017 at 8:42 PM Post #3 of 6
  No one can help me?
It seems you want the features of a sound card, without actually using a sound card.
I'm thinking you should just keep using the Asus Xonar U7.
Mar 9, 2017 at 7:22 PM Post #4 of 6
Hi, I don't agree with you. I think that there are alternatives for DAC.
As an example, I found Peace that is a GUI for EqualizerAPO that allow me for a simple, but complete, equalizer and a profile system. With a right click on its icon on the status bar, I can change the equalizer profile (one for cans and one for speakers).
As regards the Virtual Surround there is Razer Surround, so I only need to find, if possible, a volume normalizer that I use only when I watch film or videos.
Mar 9, 2017 at 8:05 PM Post #5 of 6
Check out the free programs MPC-HC (K-Lite) and VLC.
They might come with the features your looking for.
https://www.codecguide.com/
Cyperlinks PowerDVD is a great video player and might come with features your looking for.
http://www.ebay.com/itm/272259319037?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I hear mixed reviews on Razor software.
Mar 9, 2017 at 8:09 PM Post #6 of 6
Here's something that could work.
  VST parametric equalizer: http://rs-met.com/freebies.html
VST wrapper: http://www.yohng.com/software/foobarvst.html
music player: http://www.foobar2000.org
system-wide EQ: http://www.hermannseib.com/english/vsthost.htm
You can use VST plugins (such as in foobar2000) to do any type of DSP and then use VSTHost to apply it system-wide. Just search on Google for the ones you want, as well as guides for how to use them.
