joesteezy
- Apr 23, 2008
I've finally decided to spend way too much money on some headphones. I did some research and I think I am going to buy a pair of dt770's. When I first went to upgrade I was considering a pair of Sennheiser's but I think the dt770 is a better choice, mainly because of the bass as I listen to mostly electronic stuff and rap. Once I realized Id need an amp I started looking around and got completely lost. Price is a huge factor in this because I'm a college student and therefore one of the brokest people on earth, but I'm not cheap so if some really expensive equipment is going to blow me away I don't have a problem buying it, although I prefer the less expensive working solution. Here's my questions;
1) I get most of my stuff off eBay and the 250ohm version of the dt770 costs a little less than the 80ohm version. Is there a difference between the 2 as long as I have it properly amped?
2) I use my laptop for most of my listening, the only output it has is a "headphone" jack, not a line-out. I know I need something else between there and my headphones, but I don't know what exactly. I rarely use my ipod so I don't really need a portable solution, but it would be helpful. I plan on using a Sony receiver to do some amping right when I get the headphones, but I need something that I can transport more easily. I am considering the Turtle Beach Audio Advantage Micro because it is extremely cheap and seems like it would power the headphones but I really don't know. Will just replacing the soundcard help me out with anything or should I get a stand-alone amp? It looks like the cheapest option but if it wont do anything I wont consider it.
3) If a soundcard with a built-in headphone amp wont do the trick, what are some entry level options to power my headphones? Like I said, it doesn't have to fit in my pocket but I need to be able to pack it up pretty easily.
Sorry if I am asking the wrong questions but hopefully someone will see where I'm coming from. Any input on my setup is appreciated.
