Need help finding TV speakers
May 16, 2015 at 10:09 PM Thread Starter Post #1 of 5
cdahdude
Hello,
I live in a pretty small cottage and am looking for a low-budget sound system for my TV because the in-built speakers suck. My budget is about $100 but I don't mind going a little bit over. The TV room is pretty small, and I don't want the speakers to be too wide (no wider than 6-8 in.) and not too tall (maybe 2 feet max?). Does anybody know anything decent that'll suit my needs? All I do is watch movies.
Thanks!
May 17, 2015 at 12:29 AM Post #4 of 5
cel4145
grand rapids, mi
It's usually not too hard to improve on TV speakers. You should see if there is a store near you that has speakers you can demo :)
May 17, 2015 at 12:40 AM Post #5 of 5
PurpleAngel
California
  Does anybody know about the Klipsch ProMedia 2.1's? They seem to be very popular. But I do prefer the aesthetics of bookshelf speakers.
Not a lot to recommend for your budget range.
Klipsch Promedia 2.1 are a good value, $85 for used ones (assuming you like a lot of bass from a sub-woofer)
BestBuy has them new, on sale for $119.99.
Dayton Audio B652 sell for around $60 for a pair, you will also need to buy an amplifier (Lepai $25-$30).
