So im pretty new to the headphones scene. Ive been using these old astro a40s for the past several years and ive decided that i need an upgrade.
Im looking for a good set of headphones that wont hurt my wallet too much during this pandemic crisis. I will mostly use it for gaming, so a good sound stage is required, but im also looking to use it for a lot of other things like music and such.
Im currently using a behringer uphoria um2 as an audio interface that i use for my mic because i occasionally stream on twitch, so id like to get a pair of headphones that can be powered by this so i dont have to spend any extra on an amp and dac if i dont need to.
Ive heard suggestions like the philips shp9500, beyerdynamic dt770, akg k612 pro but i have next to no idea which i should pull the trigger on since i have no experience in this field.
Im not specifically looking for cheap headphones, but instead the best value headphones, if you get what i mean. If any of you know a really bomb ass pair for only like 100-200 USD that fits my needs, then that would be amazing.
