LeDave
EDIT: I made a decision to get Fiio FT1 Closed-Back Headphones. Thanks everyone.
Would you consider wired ones if the wire were more appropriate (or interchangeable)?I have decided to get a HiBy R4 soon and need a new headphones. I am currently using a Sony MDR-7506 with the coil wires and it is so long, wonky and gets in the way. My budget is $200. The cheaper, the better. But if it has to be that expensive, then so be it. Thanks!
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Definitely wired if it is doable. However I find it hard to find one that is doable.Would you consider wired ones if the wire were more appropriate (or interchangeable)?
Well, there you goEDIT: I made a decision to get Fiio FT1 Closed-Back Headphones. Thanks everyone.
