RyanWhite24
- May 3, 2009
Hi everyone,
Im new to the headphone world (usually stick with earphones) so would appreciate some advice from the pro's. I have just bought myself a pacemaker, and im looking for some headphones to go with it.
So, the question is..... Audio Technica ATH-AD700 or Sennheiser HD595 headphones? or perhaps something similar in the same price range? Could you also tell me why you have chosen a particular set of headphones? Build Quality? Sound Quality? Extras? etc.
From what i have read on this site and other sites, the AD700's seem better.
Also, do i really need am amplifier? If i do, then it must be portable. From what i have found, the Flio E5 amps seem to be pretty good, and a really good seller! Can anyone comment on this? Would this be a good combo with the above headphones? or would i not get the best sound with this amp?
My main use for them both will be my iphone, macbook pro, and pacemaker. I mainly listen to trance, dance, drum n bass etc.
Thanks in advance!
Ryan
Thanks in advance!
Ryan
