Need help choosing (fairly) cheap on ear headphones
post-8528811
Thread Starter
Post #1 of 6
TeerraM1
hi, lately i saw the skullcandy skullcrasher headphones which i quite liked the design, then i saw this site and saw all the negative comments about it. Im looking for a good pair of headphones, i am not really on top of all these makes so i came here to ask for help.
my budget is around 100 british pounds (around 150 dollars). im mainly listening to Hip-hop and metal/rock. I am mainly looking for some good bass, dont really care about the looks. if you need additional info just ask.
post-8528842
Post #2 of 6
Nappael
The Skullcandies are dreadful, just don't bother with them.
I recommended the Audio-Technica ATH-M50's to a friend who wanted the same kind of thing as you, and he loves them. They come very slightly overbudget at around £120. Other options might include a pair of HD558's, Roland RH300, or a pair of Beyerdynamic DT770's.
Hell, even the XB500's could work. They are not great, but they would at least beat the Skullcandies.
post-8528916
Post #3 of 6
TeerraM1
so you are favorable to the ATH-M50's. could someone give me a review of them? do they mute everything around or let the noise through?
im planning on having headphones for around 2+ years, is that possible? :D
And most important, are they comfortable to wear? im planning to go on a trip pretty soon and that would leave me listening to music for about 12 hours... apparently over ear headphones drain the battery from phones pretty fast, is that true?
post-8528946
Post #4 of 6
Nappael
Sound leakage isn't really a problem with them, in both directions. You will find yourself fairly isolated from the outside world. He has owned them for almost 2 years already, so I doubt you will have a problem with them unless you are particularly heavy handed. My experience with them is pretty much the same. They are pretty comfortable too, and somewhat easy to run. I wouldn't recommend a phone, but they can certainly be used with them.
There are loads of reviews on here, this is a link to some reviews of the straight cable version.  http://www.head-fi.org/products/audio-technica-ath-m50s
post-8529002
Post #5 of 6
TeerraM1
what do you recommend for listening to music? (portable and cheap).
I know that phones don't have a brilliant hardware for listening to music but what can i say?
thanks for help
post-9295989
Post #6 of 6
pashapassion
