MD1032
- Aug 10, 2003
I need help!
OK, so I'm going to use some CAT5 cable to make a small mini-mini interconnect. I picked up some overpriced mini plugs at radio shack, and I'm going to use my dad's Weber 8200 to do the soldering. I've never done anything with soldering and connectors before, so bear with me!
So, I have the CAT5 cut to size, and I cut off part of the of the outer casing, which I would like to leave on, instead of braiding them. I have the screw-on thingies and the insulating sleeves on, as you can see in the second pic. I'm using twisties to keep them down there.
The question is, what next? How do I safely strip the little wires? I already tried once with a pair of scissors and ended up cutting one of them off accidentally. I have a nice wire stripper, but it only goes down to about 20 AWG. Some help? Man...this stuff is too small!
