Hello guys, probably it has been asked, written but believe me i read much but i dont understand some points. I have Hifiman re400 and iphone 6. Do i need an dac/dap? I want to use tidal, do you think it will be effective with iphone?
need help about headphones
- Thread starter brk.loyka
I don't think you need a amp for those unless they are not getting loud enough for you and I recommend not listening too loud but that is the father in me.
Thank you dad, so can i hear hifi quality in tidal?
blackrain139
Yes, as long as you select HiFi in the Tidal app settings
Okay guys, thanks a lot
cossix
- Jan 25, 2017
Amping it should help but by no means do you absolutely need one. Perhaps if you ever decide to collect some lossless files in a desktop environment then you'd benefit from a nice dac and amp
ProtegeManiac
You'll just have headaches going from iTunes syc/streaming to drag n drop+scan on DAPs.
