need cable from av710 to zhaolu dac
Mar 7, 2006 at 5:58 AM Post #2 of 7
lan
Videographus Supremus:Makes audio cables using super-advanced materials, like "some clear tape" and "some not so clear tape."
I thought zhaolu came with optical digital cable. Mine did but i never tried it. If you want one of the recommended ones, try looking for glass toslink.
Mar 7, 2006 at 6:28 AM Post #5 of 7
saturnine
Savannah, GA
Originally Posted by Borat
Glass TOSlink Optical Cable
Here is a 6 ft version on eBay.
I can definately recommend that cable. Very good quality, and much cheaper than the ultra high priced stuff.
Mar 7, 2006 at 7:23 AM Post #6 of 7
bulls
ya the dac comes with one but just looking for something better but not crazy expensive. thanks for the suggestions i think i'll grab one of the glass toelinks from ebay.
Mar 7, 2006 at 11:11 AM Post #7 of 7
aznsensazian
Thanks for the link, just grabbed one myself.
