Need a quick musical Subwoofer for $500 or less.
Apr 27, 2004 at 11:58 PM Thread Starter Post #1 of 8
meech
Any sugestions on a fast, musical sub for about $500 or less? I need it to keep up with a pair of bookshelf speakers.
Apr 28, 2004 at 12:09 AM Post #2 of 8
fliz
build one.
sub amps are cheap used (check ebay)
and get a driver from visaton (there are many other companies too)
these can run you anywhere from $40 to $500 and NO! price does not equal performance.
build an enclosure out of mdf or sonotube.
if you want, i can provide some web sites to lead you in the right direction.
if you try, you'd probably be able to build two for that price and have stereo bass!
f
Apr 28, 2004 at 1:16 AM Post #3 of 8
meech
Thanks.
What sites can you recommend that can give me a little help in the Diy area? I've never done any DIY experiments but I'm willing to try.
Apr 28, 2004 at 1:17 AM Post #4 of 8
dd3mon
Adire Rava - read rave reviews on AudioAsylum, nothing to touch it for the price for music. (at least not assembled for purcahse)
-dd3mon
Apr 28, 2004 at 1:18 AM Post #5 of 8
ooheadsoo
http://www.diyaudio.com is the most comprehensive forum for this type of task. Looking in members' signatures for websites is a great way to find resources as you browse through their posts.
Apr 28, 2004 at 10:50 AM Post #7 of 8
meech
I think I'm going to give the Adire a try. I wish the enclosure was little smaller but it'll have to do.
Apr 28, 2004 at 12:45 PM Post #8 of 8
Hirsch
Why is there a chaplain standing over his wallet?
HSU VTF-2 works well for me. These should be available pretty cheap, since HSU now has a VTF-3.
