Jul 3, 2012 at 9:46 AM Thread Starter Post #1 of 2
abhijollyguy
Hi all,
I am using this wonderful little player Nationite Nanite N2 and till now everything was going fine, but my player stops detecting the memory card(micro SD card) it skips the external media check duing the boot-up, but it used to check it before. Don't know what is the problem, also it is not showing the SD card icon the the player, it is showing the cross sign on the place of the SD card icon on the screen. I am really not getting what is the problem here. SD card is working fine, I am playing music from SD card attached to the PC.
Resetted the player many times.
Any help will be appreciated.
Thanks in advance.
Jul 3, 2012 at 10:16 AM Post #2 of 2
Problem solved, I have formatted the micro SD Card using the NTFS file system that is why this player was not detecting the card, now I have reformatted the micro SD card using FAT32 file system and now everything is working like a charm.
Thanks for looking :)
