Can anyone tell me what the point of a 12v out is?
Isn't that the trigger output (used to turn on/off another device - with trigger input, e.g. an amp - together with the M51)?
Fortunately that is not the case - I checked with them because my serial number is 33M51xxxx. They said it would be fine. It's more a matter of what firmware you are running. If you are at 1.43 or higher you may have to roll back through prior versions to get to 1.39.
Question:
No hdmi signal pass through if the unit in standby?
