Myth: HDCD Discs Sound Better Even in a Regular CD Player?
Feb 9, 2006 at 12:00 AM Thread Starter Post #1 of 19
Counter Example: I've got an HDCD-encoded CD which sounds
bad on my non-HDCD Pioneer DV-578A-S dvd/cd player.
Johny Cash: Platinum Collection, Prime 1975. From the booklet:
"... HDCD-encoded CDs simply sound better, even in a regular CD player!"
Also the Microsoft site 'hdcd.com' states:
"HDCD overcomes the limitation of the 16-bit CD format by using a sophisticated system to encode the additional 4 bits onto the CD while remaining completely compatible with the existing CD format.
HDCD-encoded recordings sound better on all digital player products ..."
The above statements regarding the 'compatiblity' are not true!
First, I've found the following in the manual of the Panasonic DVD-F87 dvd/cd player (which I returned after 20 days, last year for a full refund):
"The unit is compatible with HDCD, but does not support the Peak Extended function. (A function which expands the dynamic range of high level signals)
HDCD-encoded CDs sound better because they are encoded with 20 bits,
as compared with 16 bits for all other CDs."
At least Panasonic is honest and says implicitly that F87 is not fully compatible with HDCD-encoded discs.
Second, I've found the explanation of this incompatiblity in
the book by Bob Katz, 'Mastering Audio. The Art and Science', 2002:
"HDCD - High Definition Compatible Digital
...When an HDCD DAC is not used, the sound quality is reduced to that
of a standard CD. However, if the mastering engineer manipulates
some extra features of the HDCD system, known as peak extension and low level,
then the music sounds compressed on a standard CD player and can
only properly reproduced (without compression) on an HDCD palyer/DAC.
Despite its name, HDCD, if manipulated aggressively, is not compatible with regular playback."
I've got also HDCD-encoded CDs by Roxy Music 'Avalon', 'The Best of Roxy Music'
and 'The Best of Jethro Tull' and they sound fabulously on my universal non-HDCD Pioneer cd/dvd player.
See you on the HDCD
Side of the Mnon
Adam
Feb 10, 2006 at 6:18 AM Post #3 of 19
what I have found is that there ISN'T a HDCD encoded disk that I think sounds bad...
it has to do with the quality of the recording itself. If the recording label/engineer even bothered to use HDCD encoding then they definitely pay good attention to other parts of the recording process.
Feb 10, 2006 at 2:26 PM Post #4 of 19
Absolutely. All of the HDCD recordings I have were mastered very well and sound excellent on any CD player.
Feb 10, 2006 at 3:17 PM Post #5 of 19
A lot of HDCDs aren't even marked. After I bought a HDCD player, I noticed that several of the discs that I had really enjoyed for their sound quality were causing the HDCD light to come on. They sounded even better in true HDCD, but they were still darn good on my old non HDCD equipment.
Feb 12, 2006 at 6:02 PM Post #6 of 19
I think my HDCD CDs sound better on my E5 than regular ones in general.
In one case I upgraded a recent non-HDCD version of Mike Oldfield's Amarok with the HDCD version and the HDCD version sounds better in subtle ways.
Could have been remastering differences other than HDCD however.
Feb 12, 2006 at 9:45 PM Post #7 of 19
Originally Posted by AdamCalifornia
" ...Despite its name, HDCD, if manipulated aggressively, is not compatible with regular playback."
This is the point I tried to make in my post.
Yes, it could be that this particular HDCD-encoded cd was badly mastered
(nothing to do with the HDCD encoding) yielding bad sound.
But on the other hand, the bad sound could be caused by
'aggressive manipulation of some extra information' HDCD-encoded on the disc
by a mastering engineer. If, someone has this particlar HDCD cd and could play it
on a fully compatible HDCD player (not like the Panasonic F87, displaying HDCD logo,
which is not fully compatible) then, and only then, we would know for sure!
I don't have an HDCD compatible player.
See you at the Winter Olympic Games
in Torino, Italy
Adam
Feb 12, 2006 at 10:34 PM Post #8 of 19
I only hae one HDCD - Dire Straits' Greatest Hits. And it sounds amazing! On my Computer!
Feb 12, 2006 at 10:52 PM Post #9 of 19
Bob Katz also stated, in his book, that Pacific Microsonics' HDCD system has a superb A/D converter. That explains a lot.
Feb 13, 2006 at 12:26 AM Post #10 of 19
Adam you could verify this yourself. Windows Media Player 9 is fully compatible with HDCD when used with a modern soundcard.
Feb 13, 2006 at 2:05 PM Post #11 of 19
Does WMP9 play HDCDs at 20 bits like a "true" HDCD player, or is it simply "compatible"? If yes, can foobar2k do the same?
Feb 13, 2006 at 7:01 PM Post #12 of 19
Yep, my ears have noticed the same thing.
Feb 14, 2006 at 1:18 PM Post #13 of 19
Is it possible to do an A/B using windows media player 9 (by turning HDCD encoding on and off?). I won't be able to do it on my machine: my PC speakers suck.
As for bad HDCDs: some HDCD-encoded Hong Kong pop music do sound bad, but this has more to do with recording than from mastering.
Feb 14, 2006 at 1:25 PM Post #14 of 19
Yes WMP is truly compatible. Also an interesting fact is that a WAV ripped in EAC will still have the extra info for WMP to read as an HDCD. Foobar does not support HDCD since it's a proprietary liscened type thing, until someone hacks the code on WMP that is
Feb 14, 2006 at 4:42 PM Post #15 of 19
It might be because a lot of the "HDCD" stuff in HK is fake.
