Okay, I did some testing, and I'm now a believer. The peak resonance in the upper-mids and the treble are the most significant changes. With the Triple-flange that has only the stalk cut off, the upper-mids are much more tame and does not require that cut at 7KHz, while the treble is also softer as well (this is comparing to triple-flange with the smallest flange and the stalk cut off). The EQ curve I use now for the triple-flange (stalk cut off) is this:
The largest comply grey sticky foam tips are also good, but I hate any kind of foam tips where you have to wait for it to expand for a seal. It's just an extra step that's kind of annoying. If I'm out and about, and every few minutes someone wants to say something to me, I'd have to pull out one ear, talk to the person, and then put it back in and then wait for the damn foam to expand. After doing that a few times, it's just too much. The silicon tips are far more convenient.
The hard semi-transparent tips I just can't use at all. Never was able to get them to sit right in the ear or seal properly, even as far back as my Shure E4C days. I don't know why companies even include those because I really wonder if anyone uses those at all.
